Canabuc
- Jan 12, 2017
It's a slightly changed BT20S. I think maybe a better antenna/lower noise floor, still elevated. But not significantly different.
Fiio is utws1 not the bt20s
Trn made the utws1 for Fiio. It is based on the BT20S with minor tweaks.Fiio is utws1 not the bt20s
Wow didn't know that. Is performed same? Heard about connection issues...Trn made the utws1 for Fiio. It is based on the BT20S with minor tweaks.
Soundpeats T2 default to ANC and Transparency off when powered on.Anyone else have issue with Wavelet Graphic EQ being not as good as EqualizerAPO Parametric EQ?
Taotronics SoundLiberty 94 sounds so much cleaner with the AutoEQ preset (based on RTings), it also shows how much can be tweaked with EQ. However, with Wavelet there is a distortion at high volumes. It doesn't really clip per se (as on my Anker Q30), but at higher volumes the snare and sibilant sounds have a hard edge to them.
Does SoundPeats T2 remember your ANC setting the next time you power them on? That's one annoyance I have with the SoundLiberty 94. I end up draining the battery quite quickly.
EDIT: Used the 94s for less than 4 hours today. Case battery already depleted. Abysmal.
KEF mu3 - no contest!Hi All, I've been away too long, been allocating my funds for an new OLED and building a new PC.
Saw a review this morning on the MW08's and thought it might be time to buy a few more pairs of TWS'.
I've been rocking the APPs, FIIL T1 Pros, Jabra 75t's and my Tevi's for a long while now and was wondering what all of your favorite TWS's at the moment are?
I still can't seem to find anywhere to buy the N10 in the USA. I wonder what the difference between the N10 Plus and the N10 Pro are? I love my N6Ps and wouldn't mind grabbing a pairN10 Pro already re-imagined into the N10 Plus with 5.2, multipoint, aptX adaptive, gaming mode and other stuff and in new colors. https://nuarl.com/en/n10plus/
Oh yeah $50 cheaper as well. $200 this time round it seems.
Moondrop doesn't necessarily develop down like that. The Aria, to my knowledge, is intended to be an evolution of the Starfield, addressing some design concerns about them in the process (chipping paint, for example). They also parts-share across their line quite a bit and I was somewhat surprised to find out that they utilized KXXS shells on the Starfield as well (ones that apparently didn't meet the polished metal spec for the KXXS).Ok well seems I may have to move to the iem threads.
Got a taste of the blon bl-01 And now just ordered the moon drop Aria which are supposed to be lime the Stanfield but maybe a bit more low end and Soundstage at lower price.
Will add so bt adapters also at some point and will have an unbelievable sound for under 150$ combined.
I’d skip the M&D, personally didn’t think much of them. My favorite is the Noble Falcon Pro so far, the Grado’s I kept also, great vocals. Would love to try the KEF’s just can’t find them in stock in the US anywhere.TWS choices...
KEF Mu3 (200€) maybe but would have to listen. I like the descriptions I’ve read
M&D MW08 (300€) the “probable” choice, but expensive
Noble Falcon Pro (330€) have read high praise, but VERY expensive
Grado GT220 (260€) I like the quality. But they definitely lack in “extra features”
Between these and the MT’s I own, what is your take? How do they compare? Are the others much better that they justify their price jump over the MT?
I prefer sound quality, and this trait is definitely the most important, but also like to have extra features, like Ambient/ANC, Qi, decent battery, good secure fit, nice easy controls (if buttons they must be soft or displaced like the M&D). I don’t care much for codecs as I’m on an iPhone (mostly) or an iPad. I listen to most genres on Spotify and Tidal (hi-fi).
It’s my firm belief that any headphone (or speaker) should play well any genre (the meaning of high fidelity) and that EQ should only be corrective if needed. But our ears are free and taste plays a big role.
Should I stay put or risk it? Which ones, any of these or any others?... too many questions. Thanks.
Think of them as a company that evolves their products more than cheapens them down. Hope you enjoy them and don't feel too bad about taking a TWS break. Just don't go too nuts upgrading now as it's pretty easy to throw money away at this stage.
Think the kef are available again directly from them on their siteI’d skip the M&D, personally didn’t think much of them. My favorite is the Noble Falcon Pro so far, the Grado’s I kept also, great vocals. Would love to try the KEF’s just can’t find them in stock in the US anywhere.
This part is what I'm trying to get you to avoid. You can spend years and thousands of dollars chasing something that better amplification will fix. You have two great entry-level pairs and will get far more out of improving the source than you will chasing the speakers. GIGO is a real thing.Based on the raving of the moondrop Stanfield at their price point I think I would need to scale up over 300$ to get a better resolving set and think there would be diminishing returns beyond that point.
Comes down to what you're looking to get out of them. What sort of versatility are you looking for? I could throw out a blanket recommendation, but want to make sure you're happy with what you end up with. Some answers to these questions will help:hi everyone. i'm thinking of buying my first pair of wireless iems. looking for something comfortable and versatile. i've read some good things about the jabra elite 75, are they still worthy? or are there better alternatives for less than 100 dollars?
i listen to basically everything but rock/metal. the main usage will be music, calls are really secondary for me, and i'm using my phone as a source. i'm honestly not too picky about the audio quality (i figure anything around 100 dollars should sound decent), and i also value comfort, connectivy and durability a lot.Comes down to what you're looking to get out of them. What sort of versatility are you looking for? I could throw out a blanket recommendation, but want to make sure you're happy with what you end up with. Some answers to these questions will help:
The EA75t are probably my favorite Jabra sound signature, but not for every genre. Bassheads will love it, but you sacrifice a good amount of detail for that fun. That may not matter to you.
- What will you primarily be listening to?
- How much time will be spent on calls vs listening to music?
- What equipment are you using as a source?
I've personally found the Noble Falcon 1 (with a little EQ) to be a better all-rounder if you're genre-agnostic like me.
If call quality dominates all, though, Jabra hands down.
What can you find? Probably best we start there.i listen to basically everything but rock/metal. the main usage will be music, calls are really secondary for me, and i'm using my phone as a source. i'm honestly not too picky about the audio quality (i figure anything around 100 dollars should sound decent), and i also value comfort, connectivy and durability a lot.
i looked up the noble falcon but unfortunately can't find them at a good price in my country. thank you for your reply![]()
