Caipirina
- May 25, 2015
s101
Well I got my FIIL T1X And I’m not sure I can keep them. They sound great for $50, playing above their price point.
HOWEVER, it took me 15 MINUTES to get my ear canal pressure equalized with the pressure behind the driver, so that they would seal well and still play freely without the drivers binding up.
This is unacceptable. I thought the “driver flex” issue was just going to be a “crinkly” sound that the drivers would make when adjusting the fit - but instead it prevents the drivers from moving properly to produce the best sound.
But what I do like is (1) they are quite comfortable vs My N6P, (2) they don’t need to be EQ’d but using EQ via the app is subtle and doesn’t ruin the sound, and (3) with a partial seal to allow you to avoid driver flex and hear things around you, they still make bass and don’t fall out.
Looks like Engadget have updated the page to say the Sony's aren't LDAC compatibleAccording to Engadget, the new Sony is LDAC Compatible. Doesn't seem right but I'm looking for confirmation - that would be a must by for me.:
One more thing about the noise cancellation: The WF-SP800N doesn’t have the same QN1e ANC chip as the WF-1000XM3. Sony didn’t go into specifics, only saying that the component that powers the pricier model isn’t inside these. The company was also clear that the WF-SP800N doesn’t support the DSEE HX software on the WF-1000XM3 that upscales MP3 and AAC audio “to near high-resolution sound quality.” However, this new model is compatible with LDAC: technology that allows you to stream high-resolution audio over Bluetooth. Plus, the WF-SP800N also has Sony’s Extra Bass chops, so there’s an emphasis on deep, rich, low-end tone.
Figured it was a mistake.Looks like Engadget have updated the page to say the Sony's aren't LDAC compatible
I don't know what they do with their AAC codec, but it is amazing.My Trond BT Transmitter has Aptx, but my Fiil T1x does not. My Tranya B530 has Aptx and sound good with the transmitter, but my Fiil T1x sound better than the B530 even though the T1x don't have Aptx.
Maybe try a foam tips?Well I got my FIIL T1X And I’m not sure I can keep them. They sound great for $50, playing above their price point.
PoopLooks like Engadget have updated the page to say the Sony's aren't LDAC compatible
I don't understand why Sony can't get their act together. They could make a killer set, but they always seem to leave a feature off or hobble them somehow.Looks like Engadget have updated the page to say the Sony's aren't LDAC compatible
Have you tried tip rolling it? I found some genetic silicone tips that work well without causing pressure build up.
That is awesome! My first thought when i saw your post was, ugh, it's probably gonna need root. Glad it doesn't as i have no need/desire to root either of my phones. heres hoping it works with Amazon music.has anyone tried this app?
https://www.xda-developers.com/make-your-headphones-sound-better-automatic-eq-wavelet/amp/
it has an AutoEQ feature to make the curve closer to harman target curve, and supports quite a bunch of selections in its library, even some cheap chifis and TWSs.
i only installed it last night, so i only have tested it with my Gbuds and WHXM3 headphone.
from those two, i really like the sound. it makes both of them really airy and less bloated. thr GBuds is airy just as it is, but this app still manages to make the mids clearer.
next I'm gonna test it with my wired ones that's listed there
