Bhelpoori
Interesting and thanks for the link. I will take a look.has anyone tried this app?
https://www.xda-developers.com/make-your-headphones-sound-better-automatic-eq-wavelet/amp/
it has an AutoEQ feature to make the curve closer to harman target curve, and supports quite a bunch of selections in its library, even some cheap chifis and TWSs.
i only installed it last night, so i only have tested it with my Gbuds and WHXM3 headphone.
from those two, i really like the sound. it makes both of them really airy and less bloated. thr GBuds is airy just as it is, but this app still manages to make the mids clearer.
next I'm gonna test it with my wired ones that's listed there
I've been using Sonarworks SoundID (https://www.sonarworks.com/soundid) which is the successor to TrueFi but seems to be better to my ears with the Airpods Pro (and other supported headphones rather than TWS) and it works very well with the Airpods Pro. Unfortunately the number of TWS supported is vanishingly small and I hit lucky with the Airpods Pro, and playback only works on computer properly as the TrueFi mobile app equivalent doesn't exist (yet??). I also have a license from TrueFi otherwise it would be expensive.
