Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
- Oct 18, 2009
Ahah, I found it again. I'd sent the file to BMF earlier, but here's the Peavey article on quadratic throat waveguides...
http://www.excelsior-audio.com/Publications/QTWaveguide/QTWaveguide_WhitePaper.pdf
TL/DR: lowers distortion and more importantly can be arrayed which is of primary interest to us.
As for the overall waveguide shape, I would lean towards a simple relatively flat suface so that it offers a planar front. I'm also wondering if Jerg's fuzzor can be somehow incorportated, since the quadratic throat uses foam at the edges to reduce beaming (not that it's particularly relevant in a headphone at short distances, but who knows), so perhaps recess the outer edge of the waveguide so we can stick in some foam that will sit flush with the surface.
OR if we're being super fancy mill out a very fine groove between the holes and put in the foam there to complete the throat profiles. It would be difficult to to get foam in there precisely though. I as thinking maybe something simple like yarn or some other kind of thread? Anything soft but round so you can just mill out a round profile and lay string in. At the edges of the throats a semicircular taper is good enough.
