Fostex T50RP Incremental Mods and Measurements
Jan 13, 2015 at 9:18 PM Post #1,550 of 2,832
OMG, incredible! Thanks for sharing your experience
Jan 13, 2015 at 9:22 PM Post #1,551 of 2,832
Thanks, already did that, but I didn't find any mod labeled "All Paxmate"
My T50RP is currently mostly DBV 3 but some differences in material I'm still playing with.
Pardon. Table of Contents Chapter 22
Jan 14, 2015 at 3:58 AM Post #1,554 of 2,832
I'll just drop these right here:
http://www.amazon.com/Brainwavz-Replacement-Memory-Foam-Earpads/dp/B00MFDT894
http://www.amazon.com/Brainwavz-Replacement-Memory-Foam-Earpads/dp/B00OLKV5LI
http://www.amazon.com/Brainwavz-Velor-Memory-Replacements-Earpads/dp/B00MFDX4YO
$20, great pads, available via Prime, what's not to love?
Jan 14, 2015 at 4:04 AM Post #1,556 of 2,832
Those won't fit without a TON of stretching and possibly ripping the pads.
I've done it with >a dozen sets of T50s, it just takes patience (a small dab of mineral oil doesn't hurt either). The secret is stretching them before trying to fit them on the headphones.
Jan 14, 2015 at 4:24 AM Post #1,558 of 2,832
Pre-stretching is the key, with just a small dab of mineral oil. I've not torn a pad yet.
Jan 14, 2015 at 8:23 AM Post #1,559 of 2,832
Magick Man,
I will try this. Thanks for the help and links!
I ripped several pairs before going with micmacmo's Inner Tube Ear Pad Flap mod for HM5 and FA-003 pads ---> Perfect seal. Easy On / OFF. No pad stretching / tearing. Your tip will help those of us without sewing skills.
Do you put the mineral oil on both sides of the flaps...let it soak in first...stretch in all directions?
~ BMF
