Kevintj604
I own both the Radiance as well as the Atticus and have done a side by side detailed comparison of both.Reading these comments and comparisons with the Atticus has certainly caught my attention. I still haven't spent over 600 bucks on a set of cans, new or used. However, I think may in the near future. I recently stumbled upon the Quad Era-1, and it's pretty awesome. Does wonders for rock and metal, and I'm not a big fan of planars. Best closed back I've heard is the Magni, but it ran a bit too hot up top. From there, people have highly recommended the Atticus. I'm set on open backs with the Quad and SR2, but haven't found the right closed back yet. Can anyone go into a little greater detail comparing and contrasting the Radiance with the Atticus? I've tried the 7200, E-mu Teak, and Magni. I've also considered the 9200, but after owning both the 5200 and 7200, I'm not convinced this would be the right direction.
The Radiance to my ears is handily the better headphone in almost every category. The Atticus sounds muddy and bloated in the bass by comparison. The Radiance has much more detailed resolution, much better slam, faster transients and more nicer tonality. Better micro and macro dynamics and overall the better bang for buck.
Atticus is very warm and easily ZMF’s darkest headphone. I think it lacks detail and is low on resolution. That being said I think it’s better built than the Radiance. More comfortable even though it’s heavier and with the right pairing of Dac/Amp I’m sure it can surprise.
With my current setup I’d easily sell the Atticus and go with something else.
If your budget is under $600 I’m not sure where you should be looking. Maybe a used Celestee or an Elegia with Celestee pads if you’re into EQ.
