Kenneth Tang
- Sep 29, 2016
Thanks, but I guess there is more to it than this.
The referred 2,5 to 3,5mm adapter also need to fit the Elear 'pocket' in the can housing, so this adds complexity and uncertainty to the issue:
http://www.innerfidelity.com/content/dimensions-elear-diy-cable-builders#W5oZJCD2WypPAw31.97
This is true. I have planned to DIY a short cable and already aware about this issue, yet still bought a 3.5mm plug a little bit thicker than that hole at Elear side. Lucky I found a 3.5mm TRRS plug fits into the hole nicely. But need to solder all the unwanted pin to ground leaving the tip to signal only.
