Focal Clear headphones
Feb 28, 2018 at 9:51 AM Post #2,836 of 12,550
If I could make the perfect headphone, the headphone would be most importantly balanced in tonality, smooth treble, and have enough warmth, but not interfere with upper-mids coherency. Highly detailed, but also balanced in tonality, not only sound like treble boosted. Treble would not be emphasized, but also wouldn't sound dark either. I like sufficient bass, but I prefer clarity more than warmth. I think as time goes by I give higher weight to musicality, balanced tonality, than the analytical. I want to relax, enjoy the music in whatever genre I"m in the mood for, and be able to go from track to track without worrying about possible boosted treble energy, etc..
When I cringe from boosted treble, that is my brain trying to protect me from damaging my ears. I have noticed some people have volume set pretty loud when it was my turn to listen at a meet. I don't want to get to that point.
Yes. Exactly what I'm looking for too. Adding to that is a headphone able to present the full dynamics of music at low listing levels, not an easy feat. I was hoping for that from my Grado RS2es, and they're close, but loose too much low end as the volume is rolled down. Do you find the Clears are good at low listening levels?
Feb 28, 2018 at 10:01 AM Post #2,837 of 12,550
Yes. Exactly what I'm looking for too. Adding to that is a headphone able to present the full dynamics of music at low listing levels, not an easy feat. I was hoping from that from my Grado RS2es, and they're close, but loose too much low end as the volume is rolled down. Do you find the Clears are good at low listening levels?
Clear is the best when listening at low level (still you will lose some low end resolve, it's just the way it is)
Feb 28, 2018 at 10:26 AM Post #2,840 of 12,550
I tried clear today here is my impression, impressive tone and balance across the frequency response, extremely good imaginng, small sound stage almost like closed headpone, but good depth hight width, poor dynamics, good bass but not punchy, playing them loud was not enjoyable shouty sound ! You want analytical very true headphone get them, want analytical but more fun more dynamics more soundstage louder bass l700 is better but maybe fatique depend on person, but clear sound is much correct to the recording, I think i agree to everyone said they are a better hd800 actually much better have stax smoothness , they are much smoother than my l700
I also find the imaging with the Clear very impressive. The comment about playing them loud is something that I'd like to hear more about from other members/owners. I noticed this the first night I spent listening to different genres and thought that it was due to my DAP. Running High Gain on my QP1R and wandering past the halfway point with the volume. Volume goes from 0 - 60 (1.08fw) and once I got around 38 - 40 things weren't so clear and distinct. Again, I'm thinking it's due to hitting the limitations of a portable player to drive a full-size HP. Not so much ability wise. But I've always been of the belief that using the highest gain setting on any type of amplifier is going to limit the amount of "quality sound" you can expect to obtain from it. So I've been researching which direction I want to take in a new DAC/AMP either portable or tabletop.
Feb 28, 2018 at 10:28 AM Post #2,841 of 12,550
Interesting you mention that. Fletcher and Munson Equal Loudness Contour curve would agree.
https://en.m.wikipedia.org/wiki/Fletcher–Munson_curves
For me, it's treble peaks that can bring out harshness or sibilance from either in the recording or the headphones expresses it more than I prefer prevents me from raising the volume. I may not be getting enough volume in other parts of the spectrum as result. This is partially why balanced signature is important. Clear should be better at this than headphones that have a bit of treble emphasis.
Feb 28, 2018 at 11:35 AM Post #2,842 of 12,550
Found a pair of Elear pads on eBay. After reading numerous discussions about Elex pads (similar to Clear pads) vs Elear pads, I expected a huge difference in tonal balance. While tonality gets somewhat darker, I found the difference not very big. Which means that the much talked about midrange suckout of the Elear is not really due to its pads, but the HP itself. I found the sound signature of the Clear with the Elear pads quite enjoyable, depending on the genre and recording quality. For bright recordings, I welcome the just slightly darker signature. Overall, I probably prefer the original pads, but it's nice to to have the option to change the sound signature ever so slightly.
Feb 28, 2018 at 11:46 AM Post #2,843 of 12,550
Pad swaps absolutely help with the mid suck-out of the Elear, you just have to use the right pads. There's a thread on the "site whole shall not be named" with measurements showing the difference between stock Elear pads and a couple different aftermarket pads.
Feb 28, 2018 at 2:40 PM Post #2,844 of 12,550
Hi ahmedie,
I do agree with you that the L700 is very airy and has a much bigger soundstage
and also agree with you in that I prefer the Clear much over the HD 800.
I too like the L700 quite much for their air, detail and clean (great SNR) sound.
But I find your impressions re. bass and dynamics interesting as they seem quite strange to me.
First, it is commonly accepted that bass and dynamics are not the strengths of electrostatic headphones (like the L700) compared to dynamics headphones.
Second, I auditioned and tested the L700.
OK the L700 had more bass than the Sonoma M1 (but that's not so impressive given that the Sonoma's bass was kind of non-existent when I tested it).
Yet any dynamic headphone I own or auditioned has much more bass than the L700. This applies even more so to the Clear over the L700 with the strong, deep bass of the Clear.
And re. dynamics, many of those headphones, and certainly the Clear, have more than the L700
OK I would agree that a few dynamics headphones have stronger dynamics than the Clear (e.g. Utopia, Elear, K812, K872, Sonorous X, VIII -- some people find it too much)
but the dynamics of my Clear are already quite strong, for me easily beating those of my HD 800 and of most planars, and definitely much more than the L700.
What kind of music did you use for your comparative tests?
bidn
Feb 28, 2018 at 4:18 PM Post #2,845 of 12,550
Hi ahmedie,
bidn
I heard the Sonoma as well. Although it does excel in clarity, articulation, and cleanliness of it's treble, I also thought dynamics could have been greater. Perhaps it was the bass like you say.
Perhaps he means less tight bass with more decay to bring out some warmth that particular dynamic drivers can express. Perhaps the tight response translates to such impression. Tight bass and not so peaky treble perhaps gives such impression of the range
Feb 28, 2018 at 7:11 PM Post #2,846 of 12,550
Yup, LCD-2 and LCD-3 are very very dark headphones. I think LCD-X is the most neutralish headphones in all the LCD line but somehow, it lose a bit of the Audeze LCD house sound to them.
LCD-4 however, still a dark/warm headphones but much much less than LCD-2 and LCD-3, you can actually hear the treble with LCD-4 and those treble are so smooth, the sound signature that you can listen to any type of music even in loud volume without fatiguing. (can't say the same on the build tho, LCD series gotta but the most uncomfortable headphones I've ever used)
Clear, in my book it's just about perfect. Not as bright as Utopia but still plenty bright but I really love the bass on Clear, very textural, goes down to very deep and the quantity is very well controlled(think HD600 but actually has sub bass extension) I wouldn't call Clear a flat headphones but in a way it felt very neutral and balance without being boring and flat!
Only thing I feel it can be improved would the stereo imaging.
Regarding lcd4, it suffers from bad unit to unit consistency. I a/bed lcd4 with hd800s listening to Janet Jackson’s unbreakable. With LCD4, I felt she was singing under a blanket. HD800S was more bright, but has a more natural tonal balanace for her vocal. Plus, I felt I combat with music wearing a military helmet.
I didn’t find Clear was bright. Clear’s tonal balance is just natural, very life-like, and truthful to a real non-colored sound. Perfect balance somewhere between Hd800s and lcd4.
Feb 28, 2018 at 7:14 PM Post #2,847 of 12,550
I'm getting proper excited now,god knows when Nintronics will get back to me to say they have arrived at the shop,for some reason I always think they listening to my headphones at home before they pass them on to me
Feb 28, 2018 at 7:28 PM Post #2,848 of 12,550
I'm waiting for you to get your Pro's as well. There hasn't been a single conversation discussing the sonic differences between the gray and red ear pads and headband.
:laughing:
Feb 28, 2018 at 7:36 PM Post #2,849 of 12,550
I und
:laughing:[/QUO
I understand the Reds are hotter.
Feb 28, 2018 at 8:06 PM Post #2,850 of 12,550
Hi ahmedie,
bidn
please refer here too as someone also said L700 is more dynamic than the clear,
https://www.head-fi.org/threads/focal-clear-headphones.861727/page-88#post-13943535
i agree with you that the clear bass should go much deeper than the L700 and is more refined and they extends further, the L700 have known mid-bass rise that make them more or less sound more dynamic. L700 also have intimate sound with unnatural imaging on side of head which make instrument on the side of ear sound larger than they should be...I use the clear with luxman amp which is a very polite amp so that may effected my conclusion on bass punch. I used game of thrones tracks,
