dongster
- Aug 23, 2016
Forgot to address one point: "Say you are in an anechoic chamber with a set of stereo speakers that measure ruler flat. When you listen to music out of these speakers, certain frequencies are enhanced because of the interaction with your body, head and pinna. How do you recreate this enhancement of certain frequencies in an IEM?"1) Any earphone that shoots the sound directly into your ears would have to take HRTF into account. And it holds true for Custom IEMs as well. Say you are in an anechoic chamber with a set of stereo speakers that measure ruler flat. When you listen to music out of these speakers, certain frequencies are enhanced because of the interaction with your body, head and pinna. How do you recreate this enhancement of certain frequencies in an IEM? By tuning the IEM to inherently have these frequency bumps in its frequency response.
Regarding 'air movement to perceived loudness relationship'. You are heading into complex territory. dbSPL varies with distance and so when coming up with HRTFs, engineers try their best to eliminate as many variables as possible. One of the ways is; the dummy head is placed at a certain distance away from the speakers and a nominal loudness is chosen that is considered as moderate listening loudness for an average human. Now I do not know what is the right distance, because then you could start talking about Far-Field Monitors and Near-Field Monitors.
But rest assured, you can be confident that the engineers take utmost care when coming up with curves. You could google for Harmon Target curve and there is plenty of information out there.
2) The way things are recorded in studio is not simply done by 2 microphones in most cases. In a studio, there is a main floor and isolated chambers. Most of the band is placed in the main floor and multiple microphones are placed here optimally to record the timbral information of the instruments as well as the spatial, reverberation and decay cues. And the number of microphones and their arrangement is not anywhere close to replicating a human set of ears. The one exception to this is the binaural recordings.
Also keep in my mind, when it comes to stereo fidelity, IEMs lose to speakers by a huge margin because when you listen to speakers, your right ear gets the most of what comes from the right side and your left ear gets only a little and vice versa. But this is not present when listening to IEMs.
Perceived Spatial cues via Speakers = Spatial information in the recording + Spatial cues due to speaker distance and placement
Perceived Spatial cues in Earphones = Spatial information in the recording
Some DAPs and DACs try to compensate this by providing a feature called the cross-feed. Not sure how effective it is though.
My point being, saying that '2 membranes in your ear should have a direct synchronicity with the 2 diaphragm the microphone' is really oversimplification, except binaural recordings.
3) I am not sure if the recording engineer would consider the HRTF because the music they record will be played via all kind of sound systems such as mono speakers, stereo speakers, multi channel systems, headphones and earphones. I could be wrong though. Per my understanding HRTFs are predominantly used by headphone manufacturers and earphone manufacturers to tune their Headphones and Earphones to replicate what the eardrum perceives when listening to speakers.
But yes, you are right, IEMs have their limitations. Its just something we have to make peace with for the convenience and amount of micro-details they provide.
The "enhancements" are unintended mistakes, the goal of iem is to reproduce whats signals of the music file, but speakers.
