kamcok
- Nov 24, 2009
What is best filters for ost? Like hans zimmer
what is the best milk for coffee ? it's really up to your preference man......
red grey gold is top rated![]()
Is FLC8s the best all-around IEM under $500????
Oh man. The driver flex on my right earpiece when I insert it in is starting to freak me out. It kinda just flexes halfway into my ear. Might have to down size my spinfits to S.
No such problems on the left side though.
That's what im using right now. Before i used red black gun metal.
Flexing happens a lot with red UFL, but it's nothing big. Happens to me every time, but mine is working well and still sounds the same. Also means you're getting a good seal.
Likely your right ear canal is slightly smaller than your left, same is the case with me. I get some flex in the right ear when using the red sub-bass with OEM or other silicone tips. Switching to gray sub-bass eliminates it (I still find sub-bass very satisfying with gray), or switching to foam tips (I use Crystal) also eliminates it s the pressure equalization is more gradual. I think as long as you don't go crazy fast and deep with insertion it will never cause a problem, and likely not even then.
Ah ok. That's good to know. What I'm doing now is pushing the eartips up as I push it in. Kinda helps as I can get it in deeper but it's a 50/50 chance as to whether I can successfully push it up or not.
@dlayman The funny thing is, when I was using the PMV A-01 Mk.II, I had to use the Yellow L Spinfits to get a good seal. I thought that the L Size would be perfect for the FLC8S but nope. Couldn't even get the tip in. The M size was a much better fit.
Anyway, liking the red>grey>green filter combi. It adds some punch without really touching the clarity. Going to try the red>grey>gold filters a try again. Maybe I didn't give this combination enough time.
But man, I really can't believe how good these sound. That clarity combined with a surprisingly wide soundstage.
Sad I can't get this to work, when I try to insert the iem into my ear canal it just won't budge in. It's like suddenly it lost all friction :/ (I wash my ear daily)
