Has anybody found a decent lightweight cable terminated in 4.4mm that'll work with the A3000 and A4000? Figure if my DAP has 4.4mm I might as well use it.
Final Audio Design Impressions and Discussion Thread
riverground
I honestly would recommend the Final C106 2-pin 4.4 but unfortunately, It’s quite pricey compared to the IEMs themselves. But you can find other CIEM 2-Pin cables out there that are cheaper.Has anybody found a decent lightweight cable terminated in 4.4mm that'll work with the A3000 and A4000? Figure if my DAP has 4.4mm I might as well use it.
You can find the cable over on Audio46 but the 4.4 is currently out of stock. https://audio46.com/products/final-audio-c106-2-pin-silver-coated-cable
The one I’ve used on the A4000 was the PW Audio Monile which costs waaaay more than the IEM. But I already had the cable so it didn’t really matter much to me. At this point I think I have way more cables than IEMs haha
They look pretty sexy with the A4000 though
Good to know that the pw connectors work with the recessed connection on the a4000 at least. Of course the effect audio cable I got for my tia trios back in the day I special order with the flat 2 pin connectors so that cable won't work unfortunately. Shame because I love how lightweight that cable is. Maybe I'll just order that same cable with the right connectors for my a3000.
pholcus1975
What about Tripowin c8? If I remember well it should fit a4000 with a little hack.
Probably could make it work but I'd prefer something thinner. Love how thin the stock cable is honestly. Goes well with how small and lightweight the iem itself is in my opinion. Looking to roughly match that stock cable bit with a 4.4mm termination.
musicasmedicine
Hi guys, considering selling my BARELY used, like-mint Final Audio A8000. Let me know if anyone's interested
jlemaster1957
Thanks for sharing. The A4000 is my fav daily driver since I paired it with L size Azla Sedna Earfit (regular ones not light or short). It greatly enhanced bass impact when I finally got a good fit. Unfortunately the Final Audio cable you shared a link for only comes in 2.5 mm balanced output now (not 4.4 mm) though not a big problem as I have 2.5 to 3.5 and 2.5 to 4.4 mm adapters- so it is probably worth it to me.I honestly would recommend the Final C106 2-pin 4.4 but unfortunately, It’s quite pricey compared to the IEMs themselves. But you can find other CIEM 2-Pin cables out there that are cheaper.
mochill
I have found a final E3000T woohoo
o0genesis0o
That’s cool. I didn’t know they have a fancy E3000.I have found a final E3000T woohoo
I hope that it is cheaper than E5000
riverground
Yeah, unfortunately the 4.4 cable is currently out of stock.Thanks for sharing. The A4000 is my fav daily driver since I paired it with L size Azla Sedna Earfit (regular ones not light or short). It greatly enhanced bass impact when I finally got a good fit. Unfortunately the Final Audio cable you shared a link for only comes in 2.5 mm balanced output now (not 4.4 mm) though not a big problem as I have 2.5 to 3.5 and 2.5 to 4.4 mm adapters- so it is probably worth it to me.
If you don’t mind having to use adapters or just wait or contact audio46 to order you some if it’s possible that’ll be good too.
I like the feel and looks of their C106 cable.
- Jan 29, 2010
Today we have a double review of the ZE3000 on Headfonia.
https://www.headfonia.com/final-audio-ze3000-review/
oh my goose
I'm looking for a regular, non-balanced 3.5 replacement cable for my Final Audio a4000. I dont even hate the cable they came with. But, after spending thousands on IEMs, I've found my endgame, and I'll be heartbroken if this cable fails and I can't replace it.
mochill
jlemaster1957
I’ve been considering the Final C106 cable. Comes either 2.5 or 4.4 mm balanced or you can get 3.5 mm unbalanced. My pref would be to get 2.5 mm then use 2.5->3.5 mm or 2.5 ->4.4 mm adapters since either will work. It’s a bit pricey and you have to decide if you want silver plated copper.I'm looking for a regular, non-balanced 3.5 replacement cable for my Final Audio a4000. I dont even hate the cable they came with. But, after spending thousands on IEMs, I've found my endgame, and I'll be heartbroken if this cable fails and I can't replace it.
I probably won’t buy this immediately since I’m planning to get a replacement cable for my Empire Ears Legend X and will first try out the stock Effect Audio Ares II that came with the LX and see how the A4000 does with that.
It is important to get a cable that has ability to mate with a recessed 2-pin IEM slot- flat tops won’t work (I’ve tried). The C106 does have, naturally but I think the Effect Audio cables should also fit.
I agree that the A4000 is a pretty sweet set, especially for the price once you figure out the tips (using Azla Sedna Earfits on it which are perfect for me).
Kiats
Something you don't see as much these days, the Piano Forte X. Paired with the Sony NW WM-1Z. Lovely listen.
Total: 12 (members: 6, guests: 6)
