Kiats
Haha! OK. It is the culmination of the experimental and more specialized iterations that were the Piano Forte range.Still haven't had time to really enjoy it yet.
efftee
- Oct 17, 2014
I've actually never considered using tips with the Lab 2 (or pianofortes), is it supposed to be worn with tips? @Kiats, what about you, sheathed or raw?
Trying mine with Toxic Cables SW V2, Great match. Better clarity, deeper soundstage.
Kiats
I tend to wear mine as Takai-San intended them to be. Haha! But my view is it is up to each individual what works best.
RPKwan
- Oct 17, 2015
Just helps with it staying put. No right or wrong.I've actually never considered using tips with the Lab 2 (or pianofortes), is it supposed to be worn with tips? @Kiats, what about you, sheathed or raw?
efftee
- Oct 17, 2014
Does it change the sound though?Just helps with it staying put. No right or wrong.
RPKwan
- Oct 17, 2015
It changes it slightly since it fits more snugly in my ear.Does it change the sound though?
Dinche
Well. That's it. I am done with Final Audio products. My E5000 malfunctioned today. This is after what, <150 hours of use over their 1.5 years lifespan. The left earpiece just gone quiet. Barely audible. This also happened to pair of E3000 earlier, but @ 79 AUD I thought it was just a bad luck and threw them away. Well @399 AUD and out of warranty (1 year only) this is the worst personal audio purchase I ever made.
Forever8895
Sad to hear that. Same thing happened with my E2000, luckily it was still under warranty so I got refunded. On the other hand, my B3 was flawless after more than a year. Have you checked the cable?Well. That's it. I am done with Final Audio products. My E5000 malfunctioned today. This is after what, <150 hours of use over their 1.5 years lifespan. The left earpiece just gone quiet. Barely audible. This also happened to pair of E3000 earlier, but @ 79 AUD I thought it was just a bad luck and threw them away. Well @399 AUD and out of warranty (1 year only) this is the worst personal audio purchase I ever made.
Dinche
Hi. Yes I have. Both cable and DAP. Its the earpiece. I emailed the retailer where I got them from. See if they can do anything about it.
Regards
dpump
- Jun 23, 2001
Final has said before that the majority of the time they have returns for low volume it turns out to be blockage in the nozzle filter. I would remove the eartips and check the filters and clean as necessary. Worth a try.
Dinche
Hello,
Thank you for your reply and your suggestion.
I haven't used these much at all. Nozzle filter looks squeaky clean. There are no signs of blockage or any dirt. Should/could I remove it at all and if so, how?
Regards
dpump
- Jun 23, 2001
Don't remove filter. If you look at the filter with a flashlight and everything looks clean and clear then your problem isn't a blockage.
Dinche
Thank you!
As said. Filter looks super clean. As I was looking at that filter, I instinctively sucked it out (on the earpiece) few times. Guess what. Once I done that. Sound (volume) comes back, lasts few minutes and then goes back to whisper quiet again?! Well. I'd be damned.
Regards
Yeah the QC is really an issue with the E series. Even when they are brand new, they can have slight mismatch in certain frequencies. I have accumulated 5 pairs of E4000 just to mix and match and get the best channel matching possible.Well. That's it. I am done with Final Audio products. My E5000 malfunctioned today. This is after what, <150 hours of use over their 1.5 years lifespan. The left earpiece just gone quiet. Barely audible. This also happened to pair of E3000 earlier, but @ 79 AUD I thought it was just a bad luck and threw them away. Well @399 AUD and out of warranty (1 year only) this is the worst personal audio purchase I ever made.
Dinche
Wow. That's the real dedication.
Sound wise, I like(d) both my E3000 and E5000, but ultimately both proved to be "a money down the drain".
I'll see what ATA comes back with in terms of my options. If its too costly, I may just sell the cable and give/sell the right earpiece to someone.
Regards
