Rick1982
- Dec 3, 2013
My Penon Volt cable doesn’t fit… but it seems the problem is the pins diameter.
I just went and took a look at the cable on their site, but it’s using the standard 0.78 2-pin as well. It should fit just fine. I wonder why it doesn’t?My Penon Volt cable doesn’t fit… but it seems the problem is the pins diameter.
I don’t know but i can’t put it inside, i don’t want to force it too much… maybe i’ll try again. I’m waiting for a Satin Audio cable, i’ll try also with it.I just went and took a look at the cable on their site, but it’s using the standard 0.78 2-pin as well. It should fit just fine. I wonder why it doesn’t?
Which adapters do you use?Really loving the A4000 paired with my FiiO UTWS3 (note, I'm using an MMCX to 2-Pin adapter, don't know if the 2-Pin UTWS3 would fit)
Thank you! OE’s seem to be the best ones.https://www.amazon.com/gp/product/B07XKWJK6T
A little pricey, but I wanted to be able to use my UTWS3 with MMCX or 2-pin so it was worth it to me
Nice Nikon EM!All of my usual 2-pin cables fit the A3k and A4k just fine.
I’ve tried the PW Audio Xerxes and Saladin, PW Audio x Empire Ears Stormbreaker (which is basically the 1960s), Effect Audio Ares II (with ConX) and the Cleopatra, and pictured below with the DHC Complement C. All without any need of cutting… I didn’t even know that was an issue.
Not much anymore unfortunately.Nice Nikon EM!
Do you still use it?
They're honestly all the same. The differences are all aesthetics unless you go for the TWS version which is shorter and have a wider bore.Hi everyone, i am gonna buy a Final type E eartip. But there are so many variants, with many colors... i read that the clear with red core is the new 2020 version, so how about the full clear (clear axis)? Are they the same? And how about blue, brown?
Many thanks!!!
Check out my review here: https://www.head-fi.org/threads/fin...scussion-thread.613641/page-702#post-16166234Hi everyone, i am gonna buy a Final type E eartip. But there are so many variants, with many colors... i read that the clear with red core is the new 2020 version, so how about the full clear (clear axis)? Are they the same? And how about blue, brown?
Many thanks!!!
