Oct 28, 2019 at 10:23 PM Post #9,061 of 11,865
Yes, final explicitly states this on its website, and I presume that is why the B series cables (perhaps other series as well) are difficult to remove. The purpose of removable cables is for replacing a defective cable, not cable swapping with other brands, at least in final’s view.
I’m very happy with the silver OFC cable on my B1. :ksc75smile:
Well, I just check if using 4.4 balance cable can improved the sounds more with my wm1a but it seems not specially with firmware 3.1 where the sq unbalance improves to be on par with the balance connection.
Oct 29, 2019 at 7:28 PM Post #9,062 of 11,865
Yes, I understand changing out cables is often due to the connector itself, so it makes sense trying out a balanced cable. I have no affiliation professionally with final, I’m just an avid fan of its products.
Interesting you found on your Sony the 3.5mm output sounded as good as the 4.4mm. I’ve dabbled with balanced cables with my gear as well, and sometimes I got the same results as you with my now ancient AK240SS. But sometimes not ...
Nov 1, 2019 at 3:54 PM Post #9,063 of 11,865
Hi how big are the final e tips size LL
Nov 2, 2019 at 10:17 AM Post #9,064 of 11,865
I saved a copy of this from an earlier post:
from: "final????????" <support@final-audio-design.com>
Thank you for contacting us and your consideration on our E type ear tips.
The dimensions of them are stated as followed:
Size Outer Diameter Length
SS 10.4mm 8.5mm
S 11.1mm 8.7mm
M 11.9mm 8.9mm
L 12.7mm 9.1mm
LL 13.4mm 9.3mm
We hope that this information helps.
Should you have any further question, please feel free to contact us anytime at your convenience.
Have a nice day and Thanks God it's Friday!​
Nov 2, 2019 at 10:31 AM Post #9,065 of 11,865
SS 10.4mm 8.5mm
S 11.1mm 8.7mm
M 11.9mm 8.9mm
L 12.7mm 9.1mm
LL 13.4mm 9.3mm
Thank you a lot :D
Nov 3, 2019 at 8:35 AM Post #9,066 of 11,865
I sold my E4000 after missing depth too much, I tried the E5000 after but has the same problem. Its shame because these earphones are great value for money and if it wasnt for the 2D sound I wouldn't have purchased the IE800S again.
Can you give some more details? Was the bass or the soundstage depth missing?
E5000 started to caught my attention recently and I had the chance to test the IE800S also so I'll be interested in any direct comparison.
Nov 3, 2019 at 1:50 PM Post #9,067 of 11,865
Not even close to being In the same league it would be unfair to compare them.
Nov 3, 2019 at 6:45 PM Post #9,069 of 11,865
And yet you said that if you'd have had the 3D sound you wouldn't have purchased the IE800S which made me think they can be easily comparable.
Ha, because I really didn't want to spend almost a grand again on iems. The E400 really would have been good enough for my limited use of iems but that lack of depth really bothered me.
Nov 5, 2019 at 1:17 PM Post #9,070 of 11,865
an image to gaze your eyes on
Nov 5, 2019 at 9:23 PM Post #9,073 of 11,865
E5000 is too power hungry, my average volume is set to 110 out of 120 max. While my N3/IT03 is on average of 80 out of 120.
