Pharmaboy
Yes! I'm going to buy the Violectric V281
I suspect you'll love the V281. It does everything well, including superb pre-amping.
(a cross between a Swiss Army knife & a large Transformer)
March 22nd: "hot ex-girlfriend" metaphor appears on Head-Fi. You were there!
I had an anxious moment listening to some bass heavy music at what I thought was a reasonable level. I started noticing a faint clicking noise, and when I took the D8000 off my head, there was heavy distortion coming through the back side of the cups.
One of the things that happens when listening to headphones with such low distortion as the D8000 is there is a tendency—at least with me—to listen at louder levels. Perceived loudness is a function of distortion content, the more distortion at a given volume level, the louder the sound appears.
The D8000 has such low distortion, partly due to the inherent nature of planar designs, partly due to the proprietary design by final, that I do listen at higher levels than with my other headphones.
Anyway, my D8000 is fine, and I”m now tuned in to the idea that no matter how good the sound is, I need to be careful with my output levels.
So the clicking noise was distortion? Nothing is wrong with your drivers?
The clicking noise was likely the driver membranes hitting some part of the driver structure ... perhaps someone with more expertise can chime in here. Anyway, no distortion, just clicking. Only when I took the headphones off did I hear distortion from the rear of the cups. Kind of strange that I wouldn’t hear distortion when on my head as well.
I’m listening now and everything sounds as it should. I just have to be more careful with that volume knob.
But that’s exactly what the tech inside the d8000 is supposed to prevent: the driver from touching any part of the magnet structure (air film dampening system).
I also had this problem when I still have them. When you turn the volume way up to ear-splitting levels, the drivers would actually hit the magnets causing the headphone to make an unpleasant buzzing sound. A friend of mine also have the D8000 and his pair has the exact same problem. There isn't really a solution other than to turn the volume down. Otherwise if you really like to challenge physics then your ears would expire much sooner than the drivers wouldYes, I recall reading about the novel driver design.
I think I just had the volume up too high when a song came on with heavy bass notes. It sounds identical to when I did my review.
I got to enjoy the d8000 at an audio show recently and i enjoyed the sound very much. The only qualms i have with them is the build + fitment. I had to adjust the cups about 55% on each side. Almost middle of the yokes. The slider was very loose fitting and the pads werent very comfortable. The material, although plush, was itchy against my skin. Do you guys know if theres possibly a revised or updated model to the d8000? Maybe leather pads or hybrid pads. And a new headband system?
Naw don't worry, planar in general handles power very well cuz most power gets converted to heat. In the extreme case of HE6 which I still own, only 3% of the power actually gets converted to sound, the rest are either lost in heat or having a hard time moving a very heavy driver. It's the only headphone that doesn't hiss at all when I connect it to a 100W speaker amp. Mind blowing stuff.Thank you for reporting this. It eases my mind that I likely did not damage my D8000. I’m actually glad this happened since it now reminds me to be more careful with the volume. The D8000 is so clean to my ears, it seductively gets me thinking more is better.
Me either... seems like Japanese company finally has some quality control issues...Very interesting. I’m enjoying by d8000 very much and have never heard that clicking noise....and I hope I never do.
