adydula
- Dec 14, 2010
My iDSD has the 4.4mm balanced jack and the 1/4" of course....I agree the smaller 2.5mm is a poor mechanical choice...more for IEMs etc.
That said you know the balanced jack has more power.
I have listened alot with 1/4 SE and the balanced 4.4mm with an adapter...I honestly dont think your loosing much at all...
If I were you to discover this difference if there really is one get a balanced cable terminated with the 2.5mm...but use a small cable, lieghtweight and flexible...like Canare like this:
https://www.markertek.com/product/l...-star-quad-microphone-cable-by-the-foot-black
I have made several balanced and non balanced with this and its excellent...light but be careful using etc..
Another thing might be to send iFi a note and see if they can install a 4.4 mm pentacom jack.
You could do this if your ok with soldering and enlarging the hole etc...but warranty goes out the window...
