Fiio X5 3rd gen || 2x AKM 4490 || Balanced Out || DSD || DXD | DTS | Android || Dual Card Slot
post-14803770
Post #14,551 of 15,648
BobSmith8901
Thanks. Just a pity I now have to go clean install (again), then go back and reinstall jkbuha's kernel (again)
FiiO - suggest you contact jkbuha, and come to an arrangement where you incorporate his kernels in your build. Would save a lot of time, give you a marked increase in performance, and you could help him (and yourselves) by supplying other hardware (X7ii) for him to develop similar solutions.
Agreed 1000%! They need to do something material to improve the performance of this thing, not these incremental, insignificant updates that mostly focus on the FiiO Music Player. Just my opinion from where I'm coming from which is primarily streaming.
post-14803834
Post #14,552 of 15,648
New Fiio Owner
England.
England.
post-14804061
Post #14,553 of 15,648
jkbuha
Dear community
Co-incidentally timed with FiiO's 1.2.3 release, here is Version 2.7 of the Modded Kernel for the FiiO X5iii. This version adds a new installer for Busybox and SE Linux for anyone who was not getting the correct msg prompts saying "Kernel Optimisation Ready" on boot (which means your scripts were correctly installed and working). This is useful timing for anyone wishing to upgrade to FiiO's latest and greatest and then applying my kernel on top. Props this time all go to prispewnic for supplying a more intuitive busybox/selinux installer.
Changelog
Version 2.7
New: Redesigned Busybox installer
New: Redesigned Permissive SE Linux installer
New: Kernel version now displayed in settings
Fix: Corrections to anyone who was not seeing the msg "Kernel optimisation Ready" prompt
Download and install instructions as per the previous release.
TWRP Version install (you should all be on this by now - refer to previous posts)
https://www.androidfilehost.com/?fid=1395089523397902029
Any requests for lower-clocked kernels (in case you have random reboots) or general comments please PM me.
Enjoy :)
post-14804866
Post #14,554 of 15,648
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
I use the Folder Option labelling my albums with dates before the title, why are my dates now no longer in order with this update?
Dear friend,
Do you mean that the folder name not sorting in order? Please send those names to us for checking first? Thanks in advanced!
Best regards
https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com
post-14805813
Post #14,555 of 15,648
tichyztech
I simply flashed the old recovery with the android tool (just check "old recovery" and uncheck everything else), and installed the update via ota.
Runs much faster after the update, even without flashing jkbuha's kernel again!?
Thank you for this. But can you please explain a bit more how to do this i'm not very technical. thank you
post-14805875
Post #14,556 of 15,648
New Fiio Owner
England.
England.
Dear friend,
Best regards
Hello,
I will give an example of one Current Folder.
(1995) A Northern Soul
(1997) Urban Hyms
(2017) Urban Hymn - Unreleased Tracks
(1993) A Storm in Heaven
(2008) Forth
Originally my folder would have been sorted correctly as,
(1997) Urban Hyms
(2008) Forth
post-14806224
Post #14,557 of 15,648
almo89
Anybody having issues installing the 1.2.3 firmware? I download and install it and it reboots into TWRP, but it says something about failing to mount and it can't install. When I reboot the X5, it prompts me back to download the firmware. It's an endless loop.
post-14806239
Post #14,558 of 15,648
west0ne
I think you need to revert back to the original stock recovery before upgrading. You can use the Android Tool to reinstall the stock recovery, go through the update process and then use the Android Tool to reinstall TWRP and custom kernel (and/or root) if that's what you want.
Reactions: Brooko
post-14806306
Post #14,559 of 15,648
ElKabong
Yup, pretty much the process i go through, a pain, just needs the extra steps you want to avoid.
post-14806334
Post #14,562 of 15,648
Yep - that’s what I had to do. Pretty painless - and IMO worth it. Still my favourite DAP
post-14806363
Post #14,563 of 15,648
New Fiio Owner
England.
England.
Hi Brooko,
I had my X5III working nicely on one of the older updates (I forget which one) so I left the WiFi off, but stupidly I made the mistake of turning it on and downloading the latest updates and here I am again having to mess around with more bugs.
I don't use any of the add-on features, I just want to go to the Genre, choose the Artist and then choose the Album. All I am expecting is that everything will be sorted correctly, following these last two updates that I have downloaded my Albums are all over the place nothing is sorted in chronological order and I cannot find any settings that allow me to choose how my music is sorted.
Are you having the same problem?
Thanks.
post-14806432
Post #14,564 of 15,648
davidcotton
X-CANs and HDAMs
Hi Brooko,
Thanks.
What's wrong with using Folder Browser for that scenario?
post-14806444
Post #14,565 of 15,648
Wouldn't work unless he has Genre as top of the tree in his folders. Don't know of many people who sort like that.
What he's after is Genre > Artist > Album
Users Who Are Viewing This Thread (Users: 1, Guests: 6)
