Fiio X5 3rd gen || 2x AKM 4490 || Balanced Out || DSD || DXD | DTS | Android || Dual Card Slot
post-14800183
Post #14,537 of 15,648
TiborG
Bratislava Slovakia
Bratislava Slovakia
Don't worry, they run automatically by the system init.d daemon every boot.
The directory init.d on the SD card is empty. It is OK ??
build.prop has a size of 4.15 kB and includes a script boot script.
post-14800217
Post #14,538 of 15,648
jkbuha
Yes that's the backup folder on the sdcard in case you need to revert.
The actual installed files should be in /system/etc/init.d
post-14800629
Post #14,540 of 15,648
Powderphinger
Midwest, US
Midwest, US
I’m getting that with 2.6 even after clearing
Cache and Davike cache amd lettong it pretty much run all day. and And I’m using regular Fiio1.2.2. I’ve reinstalled nuetron. Crossing my fingers
I'm still having this issue with Neutron. Very frustrating. Since I only use the X5 for a music player and don't stream, I guess I'll stick with FIIO's latest version.
McHoop
post-14801598
Post #14,541 of 15,648
Lafpat
Ireland
Ireland
Hi I installed the latest kernel on my Fiio X5 iii yesterday and now it is freezing every 5 minutes can you tell me how to revert back to stock kernel or If I cant revert what can I do to stop the freezing. It certainly was a step up in speed until the freezing started. Regards
post-14801635
Post #14,542 of 15,648
jkbuha
Unfortunately it would appear your player has a more sensitive CPU. Install the alternative kernel below:
https://androidfilehost.com/?fid=1395089523397899934
post-14801757
Post #14,543 of 15,648
Lafpat
Ireland
Ireland
post-14801770
Post #14,544 of 15,648
jkbuha
post-14803327
Post #14,545 of 15,648
xomanuel
Philippines
Philippines
New firmware released 1.2.3 Link
The changes and improvements about new firmware 1.2.3 for X5III and firmware 3.3.7 for X7 are as follows:
1. Added support for external M3U playlists;
2. Added "Return to main menu" option in Now Playing menu (tap the "More functions" icon at the upper right corner to select);
3. Added track info display in Now Playing menu (click the album art display area to switch between album art, lyrics and track info display);
4. Added Max volume and Fixed volume setting (can be set in System settings -> Audio settings);
5. Added sorting functions to Playlists menu (tap the "More functions" icon at the upper right corner to select the sorting method);
6. Added cue splitting for DSD tracks;
7. Added cue splitting for multiple tracks within a single cue sheet;
8. Fixed issue where the SD cards could not be selected as save location when using WiFi Song Transfer;
9. Fixed issue where the DSD tracks could not be played properly when output via Bluetooth;
10. Fixed issue where exceptions might occur when playing via DLNA;
11. Fixed issue where the adjustment of some frequency bands in EQ settings could not be remembered;
12. Fixed issue where the display in EQ setting would not refresh after a reset;
13. Improved the sorting by file name;
14. Improved the icon tapping recognition in some pages of FiiO Music;
15. Miscellaneous improvements and bug fixes.
post-14803353
Post #14,547 of 15,648
WitzyZed
Forest Park, IL
Forest Park, IL
I just spent the last several days fully wiping and reformatting a 400gb micro sd card (on desktop this took HOURS) after my card reader botched a transfer and corrupted the sucker. Thanks to my neutron database file and SQLite browser I can at least rebuild exactly as it was piece by piece. Got maybe half my music back on there. Thinking I’d have some time to enjoy my player again today...
BOOM new firmware. I can’t catch a break!
Hope to hear good things from those going to 1.2.3, however. Descriptions don’t always bare all.
post-14803358
Post #14,548 of 15,648
Thanks. Just a pity I now have to go clean install (again), then go back and reinstall jkbuha's kernel (again)
FiiO - suggest you contact jkbuha, and come to an arrangement where you incorporate his kernels in your build. Would save a lot of time, give you a marked increase in performance, and you could help him (and yourselves) by supplying other hardware (X7ii) for him to develop similar solutions.
post-14803359
Post #14,549 of 15,648
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com
post-14803594
Post #14,550 of 15,648
mikra75
Germany
Germany
I simply flashed the old recovery with the android tool (just check "old recovery" and uncheck everything else), and installed the update via ota.
Runs much faster after the update, even without flashing jkbuha's kernel again!?
Reactions: Brooko
