Fiio X5 3rd gen || 2x AKM 4490 || Balanced Out || DSD || DXD | DTS | Android || Dual Card Slot
Feb 13, 2019 at 1:13 PM Post #14,491 of 15,899
I'm on 1.2.2 and using fidelizer purist mod. Any of you experience that it's battery is discharging faster than before?
I'll have to check it out, i use my fiio every morning when walk on my treadmill, i was really low on battery so i'm charging it today, see what i get later today, i generally use balanced iem's 99% of the time so that eats away at the battery a bit too, plus hi-res files.
Feb 13, 2019 at 9:05 PM Post #14,492 of 15,899
I'll do a full battery test again. But when I was using it later it was noticeably discharging faster.
Feb 14, 2019 at 10:19 AM Post #14,494 of 15,899
A small sampling, fully charged, a little over 30 minutes with regular 16-44 flac files, balanced iem's and viper4 android running, no wi-fi no bluetooth, i went from 100% to 92% with about 6 hours remaining according to battery section of settings. So possibly 8 hours running time
with nothing running in the background minus viper.
Feb 14, 2019 at 10:35 AM Post #14,495 of 15,899
Interesting. I did a full test today with this setup
Wifi: no
bluetooth: no
Balanced turbo: On
Playing on Tidal offline Hifi/MQa files
Balanced earbud 32ohms
Volume: 45
Runtime: 6hours 5mins
If I remember correctly with this setup I run almost at 7hrs. Not sure if updated tidal app consume more resources.
Tomorrow I will full battery test with just fiio app playing flac 16-44.
Feb 14, 2019 at 11:02 AM Post #14,496 of 15,899
For those of you running in root or Fidelizer, download BetterBatteryStats or any other utility that lets you view app hogs and/or wakelocks.
If you're experiencing unusual battery drain this is the best way to scientifically determine the cause.
Feb 15, 2019 at 8:18 PM Post #14,497 of 15,899
Hi, how do you manage to run with V4A? Is it from old music player version or stand alone V4A. Tried to install V4A but no luck to run its showing Processing: No.
Feb 15, 2019 at 8:54 PM Post #14,498 of 15,899
My bad, driver is installed, driver is enabled, alas no processing, wth. I damn sure wish fiio's association with viper didn't fall by the wayside, i enjoyed it. I wonder what is stopping the driver from doing its job.
Feb 16, 2019 at 6:46 PM Post #14,499 of 15,899
Is there any DAP available that allows you to “easily” build a Queue list (like Volumio does) or an on the fly playlist within the DAP itself?
X5 III is just too frustrating. I want a DAP that just plays the music I want to play in excellent quality. I don’t want to have to be a software genius to run this thing.
Thx in advance
Feb 16, 2019 at 6:53 PM Post #14,500 of 15,899
Iphone or Android smart-phone + DAC/amp like the Q5 or iFi xDSD. Wireless or wired options + superior DAC and amp to the Android or iOS device, and all the goodness of the Android or iOS UI of your choice.
Feb 17, 2019 at 2:49 AM Post #14,502 of 15,899
Q5 and iPod touch 6th gen is what I use for work. Easy to use and great sound quality
Feb 17, 2019 at 2:01 PM Post #14,504 of 15,899
That sort of setup banned where I work :frowning2:
I just put the q5 in my shirt pocket and have the iPod touch on the desk. However, I work in an IT dept so having tech on the desk is normal
Feb 17, 2019 at 6:30 PM Post #14,505 of 15,899
Anybody having issues with the equalizer working with the stock fiio player? i have turned it on and went through the presets and notice no difference what so ever.
Whether using android mode or pure music mode, i'm on the 1.2.2 firmware. i have to use jetaudio or power player to get any effects i can toy with.
Shame about viper not being in this iteration.
