Fiio X5 3rd gen || 2x AKM 4490 || Balanced Out || DSD || DXD | DTS | Android || Dual Card Slot
Dec 16, 2017 at 10:41 PM Post #12,286 of 15,744
Signal2Noise
Wherever the music takes me
Friends don't let friends use Sony.
I normally would concur with this statement. However I do make exception for their MDR-EX1000 IEMs.
Dec 16, 2017 at 11:01 PM Post #12,287 of 15,744
superuser1
Sapta Sindhu
Dec 17, 2017 at 12:17 PM Post #12,290 of 15,744
Sonic Defender
Ottawa, Ontario Canada
Lots of very good Sony gear. Like any company they have great stuff, mediocre stuff and fails.
Dec 17, 2017 at 6:35 PM Post #12,291 of 15,744
ailean
are you using balanced?
Yes mostly balanced on both units, there was a certain analogue liveness and natural texture to some instruments on the X5 that just seems to not exist on the ZX300. The Sony feels more digital and I don't get the sounds like I'm actually playing the strings feel. A couple of songs have felt like I'm listening to a different recording but once it's burnt-in more I'll try those back to back rather then relying on my memory. :wink:
Dec 18, 2017 at 6:11 PM Post #12,292 of 15,744
golfinggino
Can anyone recommend a balanced cable for the X5 I have been looking on Amazon Canada and can't find the one I'm looking for. I want to use with my hifiman edition x v2 so I need 2.5mm into both sides of the headphones and 2.5mm into the fiio - any recommendations - thanks
Dec 18, 2017 at 7:48 PM Post #12,293 of 15,744
MinnieOne
I think they will custom configure if they don't have what you want, worth a contact. https://www.dysonaudio.com/collecti...iman-he400s-he400i-he1000i-oppo-pm-1-cable-2m
I bought a cable for my HD600, well made.
Dec 20, 2017 at 5:56 AM Post #12,294 of 15,744
FiiO
Sponsor: FiiO
Guangzhou,China
Latest FW proves Fiio continues to disappoint us with shoddy programming: according to Pure & Android mode I have only 1 song by each of the artists in my library & I have no idea why it is showing wrong images.
Dear friend,
Sorry to hear about that. Read that the issue solved now. Each artist should have not only one song and the image is embedded one or external one? We would report to our engineers about that still. Sorry for bringing inconvenience to you.
Best regards
Dec 20, 2017 at 7:28 AM Post #12,295 of 15,744
markrich
Europa!
Dear friend,
Best regards
I still have the same behaviour with images being wrong on the new firmware version too.
The behaviour often manifests itself in two ways,
Two albums of the same name by different artists will show the artwork for the first artists as listed alphabetically.
For example, "Dark Side of the Moon" by Flaming Lips and "Dark Side of the Moon" by Pink Floyd will show artwork for Flaming Lips in the list of albums. Playing the album shows the correct artwork.
There is a secondary problem here with the music app where searching the for the album shows song 1, FL version, song 1, PF version, song 2, FL version, song 2 PF version. They should be listed 1-10 (or however many songs there are) for each album in turn. Playing this album results in the playing of both in the order it was listed.
The second example of artwork problem is when browsing the albums or songs. The music app often takes the artwork from the preceding album or song when showing on the list. Again playing shows the correct artwork.
All artwork is embedded in the ALAC or FLAC file.
Dec 20, 2017 at 11:45 AM Post #12,296 of 15,744
sjb57
Dear friend,
Best regards
It might be helpful if the process of installing new FW included a reset & rescan of the music database to ensure a clean installation to avoid such bugs from creeping in? The extra time to do such an automated rescan would minimal during a FW upgrade especially if it improved our user experience? A full Factory Reset should only be done by the user.
Dec 21, 2017 at 4:57 AM Post #12,297 of 15,744
FiiO
Sponsor: FiiO
Guangzhou,China
Dear friend,
Thanks for the kind feedback. We would report your suggestion to our engineers and consider whether it could be available.
Best regards
Dec 21, 2017 at 6:44 AM Post #12,298 of 15,744
bluedolphin
This christmas i ordered a Red Fioo X5 III Leather case
for the X5 III i purchased some months ago.
It look awesome is darker than on the photo and i absolutely recomend it
I have the Black X5III but it still will look great in it
Photos of my X5III Leather case red
which arrived to me this week
Dec 22, 2017 at 12:22 PM Post #12,300 of 15,744
Demo3
I'm still having the offline Tidal issue whereby it will glitch after about 4/5 songs - restarting the song cures it and it plays cleanly for about another 4/5 before doing it again. I have noticed that it doesn't happen with bluetooth headphones - only cabled or coax to an external DAC.
Anyone else?
I have the exact same problem and gapless playback of offline files does not work.
