teardrop3d
- Dec 16, 2006
Dear friend,
A user aslo mentioned the sampling rate supported using Airplay.
Currently, the Airplay M6 supports is up to 44.1k.
Best regards
Thanks. Unfortunately all files that I a using for comparisons are actually 16bit/44.1khz (and in ALAC) format
So.....
I understand that sound quality is subjective but it sounds very different. It's almost as if the music in unamped (that's the best I can do!)
As far a I know, audio over Airplay is always converted to 44,1kHz 16Bit, and all audio with higher bitrate or sample-rate is sampled down to 44,1/16. Personally I don’t have any issues with Airplay.
I use it for playing Apple Music on iPhone Airplayed directly to M6 (with wired IEMs’). Sounds pretty good (better than over bluetooth SBC anyway. A shame that the M6 doesn’t receive AAC over BT…yet?)
Are you using Airplay together with Bluetooth (iphone >Airplay >M6> BT> Headphones? Maybe the DAC / CPU can’t handle these simultaneous conversions well.
Yeah I can't wait until it can receive AAC (if ever!) or I just need Apple Music issues to be solved.
I'm actually also running the Airplay to wired IEMs and Heaphones when testing. I found that Airplay to M6 BT-out requires a little more testing - I am getting a lot of skipping in LDAC mode - I suspect that this is a signal interference issue with Airplay or also could also be the CPU....
Happy to hear other people's thoughts... Although I suppose this is a good as a reason as any to sign up to Tidal Hifi
