greenflash
Good question. I read somewhere that you should install it to internal for better performance..Going to try getting Spotify on it later. Do you copy the installation file onto internal or SD storage
APk file?Good question. I read somewhere that you should install it to internal for better performance..
Yep but not sure how it does work in practice, as I don't have the M6 yetAPk file?
yeah like BT-Wifi-WithFon. Damn means no spotify streaming at work for me. I downloaded spotify songs off line last night, but this morning they have gone.@gazzington would that be if you were connecting to something like BT-Wifi-WithFon - if the case i am fairly certain the M6 cannot do that / push to a web page type log in
Dear friend,Airplay issues
I've just bought the M6 a couple of days ago. Mainly got it so I could Airplay Iphone -> M6 -> LDAC/Aptx Headphones
However can someone please confirm that there are some serious compression happening with Airplay?! Is this compression on the iPhone side or the Fiio side??
Test case. I have the same ALAC files stored on an iPhone XS and the FIIO M6.
Headphones connected wired to the M6.
When I play from the M6 the songs sounds crystal clear with a fairly large soundstage (tested using SYML's Mr Sandmand and a few Vallis Alps songs - Run, Young)
ALAC files played from iPhone and Airplay'd to the M6 sounds awful. Soundstage is like a cheap headphone and definite compressed frequency (SYML Sandman really shows this)
Played the same songs with TIDAL Hifi (on a free trial) sounds great - pretty much like straight from the M6
This confuses me. In fact the airplay sounds worse than the BT-in SBC from the iPhone > M6. I thought Airplay doesn't have any compression (it essentially uses ALAC).
To be honest most of my wireless kit supports AAC (like BTR3) which sounds waaaay better than the current Airplay - and is more convenient....
This is a huge disappointment for me. I could have lived without Apple Music App (or until the issue is fixed) if there was the Airplay option but this pretty boxes me in to using TIDAL or FLAC files stored locally.
If I beam my music from an iOS device to FiiO M6 via Airplay, can I enjoy let's say a 24/96 flac files without being downsampled?
Coz from what I know in the past Airplay only supported up to 16/44.1 (kinda confused with this tech/info. )
Airplay issues
Apologies if this has been answered already.
Does the M6 permit downloading Tidal MQA tracks for offline playback?
I can't stream at work. Blocked and there's not enough bandwidth anyway
