@FiiO, today finally my M6 arrived.
It's really a little beast. Superb value for the price.
Thank you for making such a great product.
Anyway I want to ask 2 questions:
1) I have some SACD iso files.
I tried to copy them to the SD Card.
The problem is FiiO Music app can detect some of them and add them to the library but fails to detect some iso files too.
Is there any limitation on playing iso files? Maybe max file size allowed or something else?
The SACD/iso files that I have are equal to DSD64 only so it should be playable based on your specs but some aren't detected.
2) Also I want to report something - maybe a bug or something - hopefully you can help.
Issue: Suddenly the internal storage becomes full (2 GB internal storage suddenly filled up)
I tried to turn off and turn it on again but it remained full.
I only installed ES explorer and then after playing some songs via Tidal (already directed download destination to SD Card), the internal memory becomes full.
I used ES explorer to scan internal storage but the large portion of it was only stated as others (grey color) (size: 1.78 GB).
I tried to look around to delete any big file on internal storage but could not find it (already turned on hidden & system files toggle too).
So I was forced to factory reset the M6.
Now I haven't installed ES Explorer or other apps yet. Internal storage is at 724MB now.
Any idea what may have caused the internal storage suddenly became full?
Thank you.
All our DAPs can't supports ISO files with DST format. plz check your file again. for the second issues I will ask our PM to reply your question.
