Added some impressions of the DD C-M6 case for the Fiio M6 on the original review. Re-posting here below as well:
DD Electronics - C-M6 - PU Leather Case for Fiio M6
The Fiio M6 has quickly become one of my favorite DAPs for daily portable use. Fiio haven't released a specific case for the M6, so I found one at the
DD Electronics store. After exchanging a few emails directly with a Fiio representative, they kindly arranged a sample of the M6 case (along with another Fiio product-
to be reviewed soon). DD carries a few accessories for other Fiio's products and various cables and interconnectors too.
Links:
DD Electronics website and the Aliexpress store.
The
price is $16 and can be purchased from the
Aliexpress site here.
The case arrives in a very simple cardboard box conveniently arranged with a plastic foam inside. Nothing fancy and actually matches the own Fiio packaging with their simplistic and discreet packaging. The only extras you get with the case are a few of 'Hi-Res Audio' stickers to attach to back of the case (not that it will improve the quality anyway).
The case is available only in black color which fits well the own M6 player color. Quality of materials seems to be durable enough, at least for the price. Haven't used for more than two weeks as to comment much about the durability in the long run, though, but it works properly to give a better grip on the device and adds the necessary protection over the included stock PU case that arrives with the M6 itself.
The case is made by multiple layers of different materials. The outer cover is logically all PU leather - no real leather to be found at this budget prices but still gives a nicer look to the player in addition to the better protection. The inner layer is made of a fabric material with a soft and very smooth finishing. A more important feature is the middle layer that holds a steel plate for the back part of the player; it is thin enough to maintain the light weight of the M6 player but also adds the best protection for it.
The shape matches perfectly well the design of the M6 with rounded corners. Like the stock PU case, the C-M6 case has no openings for the 3 playback side buttons or for the micro SD slot, but of course it has the hole for the Type-C USB port at the bottom. The left side still has 3 marks for each of the buttons that can be discerned without looking at the player, and fortunately does not affect the sensitivity; in fact, it works as good as without the case and even a bit better than with the stock case. The fit is very tight and needs some effort to remove the M6 from it. It is a good thing but will make it tedious to remove the now concealed micro SD card if you tend to that too often.
The front side is completely open revealing the whole small touch screen of the player, but there is still the extra layer around the corners so it is only possible to remove the player from the upper opening. As can be seen there is an extra metal ring added to the back of the case so can be easily attached to a lanyard or clothes. It is attached by a single piece of PU leather material and the only weak point of the whole case.
Overall, this case works neatly for the price. It is more convenient than the included plastic case, gives a better grip and more importantly adds the needed protection.
