Many headfiers have requested a podcast app and an audiobook app. It has been proved that there are various other software apps that will work on the M6 without compromising the processor. FiiO could whitelist those apps as well as an alternative music player as the FiiO app leaves a lot to desired. I agree that in the most part the firmware is good but it has some faults. The M6 is a great little player and sounds exceptionally good and I would recommend it to anybody.
So I had a chance to play around with it on my drive back from Milwaukee. Pretty sweet player. Couple of questions:
1) Which wireless protocol are you guys using? I ran aptx-HD, never had any dropouts. But my Toyota's speakers aren't as good as the ones in my VW were.
2) Is there any way to do a true "line out" with wireless/bluetooth the same as if I connected through the headphone out?
I could be wrong, but I’m pretty sure all Bluetooth protocols use lossy compression, so whatever codec you choose, it won’t be the same as connecting via a lead and using line out.
If you’re using aptx-HD in your car with no problems, then I would say stick with that. A car isn’t a great environment to listen to music to start with, and and it sounds like your speakers a bit of a limiting factor too. You could try connecting using LDAC, if your car supports it, but I would doubt you would notice any difference. In fact you could possibly use a lower quality codec than aptx-HD and not notice any difference.
If I’m using a Bluetooth speaker,or connecting a device wirelessly in the car, then I’m not too fussed at what codec I’m using. If i’m borrowing the wife’s Sony Bluetooth headphones, then I’ll use aptx-HD. It seems to work fine and sounds great. LDAC in the M6 can be a bit flaky at times anyway...
If I’m using the M6 at home, then I will use line out and connect to my hifi. This gives the very best sound quality. I think the main reason why it sounds so good is because when using line out, I’m using the M6’s DAC, which is where all the magic happens.
When using Bluetooth in the car, the digital to analogue conversion is done by the receiving sound system, which will probably more of a limiting factor than choosing a slightly lossy codec.
Did someone compare Fiio M6 to Shanling's DAPs? I have Shanling M3s which is great, but I am considering something smaller for Fiio FA1.
I need a DAP with at least 12h of battery life (the more the better), ReplayGain and gapless playback (at least FLAC files).
M3s with FA1 has nice synergy. Since I bought FA1 and sold MEE P1 I do not demand so powerful DAP as M3s. So slightly less power with better battery life would be amazing.
M6 looks like optimal DAP, but I would like to know opinions about sound.
I'm thinking about getting the Fiio M6 plus Fiio Q5s but, because I am afraid that the m6 is too slow, I was wondering if it would be possible to control the M6 via Airplay and the m6 would send the LDAC signal to the Q5s, I mean, using the M6 as a bridge that improves the signal between the iPhone and the Q5s, is that possible? thanks!
another option is to merge m6 with q5s and buy the m11 directly but not sure about this way yet...
Just had to do my first hard reset with my M7 (hold power and play button for 10 seconds). The player reset and seems fine now but I was a little shocked as it has not given me any problems since I first got it. Was wondering how common it is to have to hard reset the M series players.
I have the M7 not the M6, you can't install additional apps on the M7. This is why I really need Fiio to finally fix the issues with the Fiio Music Player.
I got my M6 shortly after release and put white listed Spotify on it. The M6 is still going strong but Spotify is really slow and needs update, do you guys know if a new version of Spotify is available?
Is there a link?
Is there a link?
You will need to download the current .apk file, copy it to a micro SD card and install it on your M6 using the File Manager. Of course you would want to uninstall the outdated version first. The Spotify app updates frequently so you will likely never have the most up-to-date version unless you want to do this over and over.
