pooley
- Feb 5, 2012
just checked on my m6 and it also has it as a 7570
Kent
Dyslexic programmer? It is weird, but if we all had 1GB of ram it would be a very different DAP.
First I thought so too, but the mentions of the 7270 only show the sdk used for the kernel. The hardware says 7570. I don't get it either way - why would they use a better chipset and if not, why would they use a hardware command for an unsupported chip that clearly exists?
I just thought about it, but what has the processor to do with the ram built in? Shouldn't the rams used in the device be another chip on the board?
https://www.samsung.com/semiconductor/minisite/exynos/products/mobileprocessor/exynos-7-quad-7570/
Here they only mention the support of eMMC 5.0 memory. but not that it is built into it
I have an answer to why the M6 is worldwide out of stock.
I search a couple of days now, and after looking a few things up, I think I get why.
I tried to do some stuff with the M6 over ADB, and after looking around a bit, I found out that the Exynos chip inside my (!) M6 is not the same as the Exynos Chipset that is promoted by FiiO.
The Chip that FiiO promotes is the Samsung Exynos 7270, however mine has the Samsung Exynos 7570 in it. In a statement that FiiO did (only in chinese), they told that Samsung does not produce the 7270 chipset anymore, and that FiiO first needs to find an alternative. Now I'm not sure how rare it is to get the M7, but the M7 and M6 share the same 7270 chipset.
Maybe I got some kind of new model or prototype? I ordered mine over a seller in italy who had it directly out of Guangzhou. Maybe they experiment with a new line of M6s after they saw how few got manufactured before Samsung ended it entirely.
Not the best picture (should have changed my phone instead of buying a DAP )
But says also "Hardware name: 7570 SMDK board (DT)". This is really strange..
PS: I was going to reboot anyway, in more mundane affairs, FIIO music is failing to load any song in my SD Card. Read that problem up there somewhere..
So it’s not building a database from your micro card? How’s it formatted? Have you used it before? What size and brand?
I’ve used 3 cards in mind with no problems.
Well, in your screenshot it says "database.txt is empty, maybe you should update it..."
Have you ejected the SD card and put it back in when the device is off? FiiO Music always crashes the first time when it does a scan (a manual scan I have to force when new music is on the card), and after that the music app has renamed a bunch of files, like from Björk etc. - Guess it has an UTF8 problem, even though the OS does read / write in chinese lol
Besides that, it's interesting what we managed to see today. I hope FiiO has something to say, since they look in this thread from time to time. Maybe they see that a lot of people would like more control of their devices too...
It's exFat. A nice Sandisk brand, 64gb. Always worked fine but.. see below.
Jesus Christ eagles eyes huh (very interesting technical detail you noticed by the way) - Yeah I had reset the database hehe, on trying to scan again, I got zero songs to add. You know what fixed it? CHKDSK in windows. Good ol' chkdsk. Somehow there were lost clusters or something. Did that, re scanned and there we go.
The eject/put back thing is something i'll try the next time.. but it's definitely some buffering thing? that lost data. The player got totally drained (from full charge.. odd).
I have the Same issue but in the File Management App. Eg: All folders starting With a B are listed together. BUT they are not in the correct alphabetical Order. Very strange. The M3K has No problems With that. My 256gb Card is FAT32 formatted. Dont think EXFAT would Help here
