I believe that 50 days is reachable, but when device is off. 50 days in standby mode? Not possible.
[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
karhujanis
When device is off - any period is reachable.
RikudouGoku
Member of the Trade: RikuBuds
no because your battery still discharges even if the device is turned off.When device is off - any period is reachable.![]()
Fiio is mentioning deep sleep in order to achieve that standby, but even if i stopp the music, close all the apps and don't touch the M11 I still have around 10% battery consumption in one day, so 50 days seem to be imposible.I believe that 50 days is reachable, but when device is off. 50 days in standby mode? Not possible.
ADANMTXT1
I also have the X5II matched with the A5 amp. Since I purchased the M11 i haven't picked up the old unit (sadly). The sound, speed, build quality and capabilities are leaps and bounds ahead. Also I don't feel the need to use an amp for the M11 with my Sennheiser HD800 headphones... it's just that powerful.
Strangely enough - since I purchased my M11 my X5II sits unused. After 5 or 6 months I turned it on and it still has a full charge. So maybe it is the android side of the M11 using up power even when turned off ?no because your battery still discharges even if the device is turned off.
- Mar 20, 2013
It's like comparing a Nokia 3210 with a Samsung S10![]()
Nokia 3210 had the unbeatable snake game on it
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Aiuto! Roon 1.7 non funziona con il mio Fiio M11 !! Non riesco ad aggiornare dall'1.6 all'1.7. Il mio core Roon è già aggiornato ma roon remote (solo in m11) non si aggiorna e non va.
It definatelly something on m11 android side because when i purshased m11 with default version of android it seemed that it lasted much more i even surprised how long it takes to discharge but soon came new version and after this it began to discharge more quickly so now 50 days is impossible to last, more real is a week. But don't know what fiio could say there, do they investigated this.Strangely enough - since I purchased my M11 my X5II sits unused. After 5 or 6 months I turned it on and it still has a full charge. So maybe it is the android side of the M11 using up power even when turned off ?
salla45
- Mar 12, 2014
you need to download and install it via the Roon website.Aiuto! Roon 1.7 non funziona con il mio Fiio M11 !! Non riesco ad aggiornare dall'1.6 all'1.7. Il mio core Roon è già aggiornato ma roon remote (solo in m11) non si aggiorna e non va.
https://roonlabs.com/downloads.html
and then select the APK file shown below. The copy this to your M11 and install it manually.
ps... better uninstall the version 1.6 on your M11 before installing the 1.7 APK file.
errore
salla45, grazie mille!
ora funziona benissimo
Mp0wer
- Nov 6, 2012
Just received my M11 and the battery was completely dead, wouldn’t turn on.
Is there something killing the battery when turned off ?
radarnigz5
having problem with my desktop using m11, it stutters on videos and music, but not in games, im using latest firmware, original cable on usb 3.0 port
no one?
Total: 19 (members: 0, guests: 19)
