I was also ‘married’ to an iPhone for a long time, but seriously considering switching to an Android phone after my positive experience with the M11. You should check out the LG V-series: Sabre 9028 dacs and high impedance output support. Won’t sound as good as a dedicated dap, but for streaming music it should be more than ideal.Do not get it. I like to have all my Streamed music on the go when walking my dog or going on travels. And obviously one device is very practical for this. Tried e.g. iPhone with iFi DAC but it is just too unpractical. I love the sound of my Sony NW-ZX2 but it is just too old now for Qobuz streaming etc.
[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Richter Di
Interesting. Don’t think I have any tracks in 88.2 kHz
I’ve tried 24/192 and it doesn’t work.
Here you will find a link to a free 88.2
https://www.head-fi.org/threads/ama...roblems-on-the-fiio-m11.916710/#post-15237714
Mind blownHere you will find a link to a free 88.2
it worked on first try
I got in touch with Amazon support because I wanted my money back for the HD music subscription, they replied with this, maybe if enough of us do it they will fix it.
1. Launch the Amazon Music app.
2. Select "Settings" from the menu.
3. Scroll to the bottom of the "Settings" screen, then tap the “Version” row 5 times. You'll see a message confirming that “logging has been turned on.”
4. Try to recreate the problem or issue you've been experiencing. If you can, repeat the steps you took when you first came across it. This helps make sure as much information as possible is saved to the log files.
5. Select "Settings" from the menu, then select “Email Debug Log." Describe the problem you've been experiencing in the "Give feedback about this app" section, and select "Send" when you're done.
This sends an email to our technical team with your description of the issue, along with your log files.
Richter Di
Mind blown
Very happy for you.
Thanks for sharing the information.I got in touch with Amazon support because I wanted my money back for the HD music subscription, they replied with this, maybe if enough of us do it they will fix it.
FYI, I've been doing the "trick" with 24/96 kHz files and HiBy. Start HiBY, play a file. Pause. Launch Amazon HD app. Play anything. Usually works first time. Amazon reports when you touch the HD or ULTRAHD icon that the device is capable of 24/96 kHz, but it still only plays at a max of 24/48 kHz. Same as my LG V20.
Sounds pretty darn good though. But it's not up to TIDAL MQA yet.
Richter Di
Interesting my Amazon app says that the FiiO is only able of 24 bit and 88.2 kHz. Why is yours showing 24/96?
Here we go. Install 16.3.2 just out from Amazon on apkpure. Get a 24/192 kHz file. If you don't have one
http://www.lindberg.no/hires/test/2L-082_stereo-192kHz_01.flac
Open in HiBy play a few seconds. Pause. Open Amazon HD app. Go to best of ultra HD play list. Play ELO Mr. Blue Sky.
Click on the ultra HD icon to see what the track quality, device capability and current playing at : all 24/192 kHz
Bingo!
Bingo!
Can confirm the above worksHere we go. Install 16.3.2 just out from Amazon on apkpure. Get a 24/192 kHz file. If you don't have one
Bingo!
thanks a bunch!
MichaelOH
- Jan 29, 2009
....how do I purchase poweramp on the M11? Can't figure it out! Any help would be appreciated!
SoundChoice
When I go on this page to Search this Thread and enter “register poweramp” I found this
https://www.head-fi.org/threads/fii...fi-two-way-ldac.902622/page-360#post-15095699
Stenkataub
I bought it from their site. Through google chrome on fiio m11. Then I downloaded the application again from their site. In the app itself you go to the settings - already purchase it. There you enter the email you used to sign up for their site at the time of purchase. You also enter the order number from the email. And you're ready.
JLW654
Tried complete M11 reset with cards out. No use still out of sequence. I can't understand how the tags can be wrong when they show correctly everywhere else. It's the name of the folder ie Artist that is the name of the folder so they should be no reason that they are wrong. Must be the Fiio music app?? Stil puzzled, I will email support see if they know. Thanks again for your suggestion.I will look at these options thanks for your help.
Ghost Of Lundy
I have probably a dumb question.
I recently bought a pair of Sony MDR-1A-m2. They are awesome. But I didn’t want to take them to work as I normally want to use my bluetooth ath m50x-bt
Well I grabbed the balanced cable form instead of the normal one I use accidentally and I used them with the m50x with the player.
it sounded good. I know it’s not a balanced set of cans and it’s not balanced but My question is, will it damage the headphones or the m11 if I continue to do it.
Thanks
Thanks
Total: 6 (members: 0, guests: 6)
