Mine usually takes ~1 minute per 1000 tracks...so about 35ish minutes to scan my whole library, vs. Hiby taking about 15 for the same amount of tracks.
Have the same issues! Have tried some of the same steps with no result. @FiiO I have my FiiO M11 and my Samsung A8 (2018) side by sie. On the FiiO M11 only wheel spinning on the Samsung A8 direct play back. I agree with you. This is fascinating. I downloaded whole playlists and I still get the circling play/pause button. It also does not work independent if the playlist or songs are HD or Ultra HD. Do not know if this is helpful. On my FiiO M11 also on Qobuz when I start my first song of a playlist which is completely downloaded (CD quality) it takes incredible long to start. Often like 30 seconds. This is not the case with the FiiO M9 or any other device. Other thought my FiiO M11 is not shown in the device list of my amazon music settings. Might this be the reason?
I hope you get an M11 Pro and sort out the hype from reality. All these reports of “much better sound, especially bass”, but I’ll only trust it if and when you say it.
I'll hopefully have it soon. If not it will be the 1st FiiO DAP I did not get since X5II. Who is saying it has better bass? On what part of what song sounds different and how?
Good question! I don’t know. It’s been shipping for about two weeks now and aside from the odd “it’s better” comment there’s been nothing. Compare that to when the M11 launched with a proverbial flood of impressions. Either FiiO have only released a small amount of stock to market, or it’s not selling anywhere near as quickly as the M11. As an aside (and slightly OT) have you heard the AR-M2 dap? It’s an older model, but wondering if anyone in the know has experience with it.
Dear friend, Would you mind sending one of this AAC file to us for check? As for the scanning problem, please also send a log file to us: How to grab the log files from M11: https://www.fiio.com/newsinfo/239924.html Thanks in advanced! Best regards
Dear friend, You may try whether the factory restore could help? Please send a log file to us for check if the issue happen again. Thanks in advanced! Best regards
Again, I do not like that proposition and I believe I am not a only one. This is a most common way to navigate throught a lot of music-specific lists. You can scroll to desired letter by slider, and just use a scrolling gestures to navigate to desired track - from my point of view it is not a problem. In desktop file browsers I believe almost all users uses scroll wheels in their mouses to navigate - using scroll wheel and scroll gestures are exactly the same way to navigate throught files list, only difference is different tool. In desktop you are unable to quick navigate to desired letter using scroll bar, you need to press a letter on your keyboard, or couple of letters for precised search. But you have your keyboard in front of you. On android devices (or other touch-navigate systems like smartphones) usually you are not using physical keyobards (and I am not sure mentioned functionality is implemented in Android), so it is nice to have a possibility to quick navigate throught lists by a slider. For my opinion, leave it as it is, or integrate both methods into one slider - quick navigation to desired letter and scroll throught files starting with the same latter. Just show us a current letter and leave it at the screen until scrolling stops, or another letter is on a screen, or show it and dissapear until another letter appear on a list.
yes but my albums are numbered which eliminates the use of a-z scrolling immediately. The alternative is simple. Have both options available and selected via Settings.
So how do you navigate throught your albums on you Windows or Mac? Right now you have a built-in alternative for searching desired album - you can use search bar on a top of Fiio Music app. You are a very specific person - in case of tagging music library - so your above proposition is the only way to do this
Woah there M8. How does me asking for an option to allow for a scroll bar somehow cause you a problem? It's not likely to happen so ease up PS... I use Roon on PC and there's a scroll bar, hardly surprisingly, and also is extremely quick using arrow keys in any case. ALSO i can type in for example 07 and go straight to albums 07000 and above. And yes I'm quite aware of the search box in the fiio app thanks. I like to scroll through albums in date of acquisition order and numbering them is the only sure fire way I've found to do that.
I've got the Pro, but unfortunately don't have the regular M11 to compare directly. Honestly, I don't know if the Pro is worth the bump in price for people who aren't "spec-hunters". It certainly sounds good, very clean..but so does the regular M11. The Pro is also a slightly larger and heavier device.
That’s easily the most balanced and straightforward response I’ve read anywhere. Thank you. For me an ‘upgrade’ over the already excellent M11 would need to be substantial, not incremental. So possibly an M15/Pro or an as-yet unknown device down the line. Though I’d like to get at least a year or two of life out of the M11, by which time there’ll be options aplenty judging by the pace of progress in this market. Just to make the point, I’m currently testing a ‘flagship’ kilobuck dap from a few years back, the AR-M2, and aside from its obviously excellent SQ (with some IEMs) the UI and software is antiquated and buggy by comparison to the M11. Things move fast and jumping to every new ship that sails by is the surest way to ruin.
