Dear friend,Yes sure. this one:
Please try to slide up and down on the album page, can the hidden alphabet scroll bar appear?
Best regards
Poweramp bypasses Android but has it’s one resampling driver, even on DAPs with DTA. That’s just how the software is coded. Sounds great but not quite as great as FiiO Music, and since I don’t EQ at all, I don’t need to use Neutron and its horrible UI.Yes I like Power Amp, and indeed have it also installed on the M11, but it's working via Android framework; not using the DAC directly, as I understand.
I think I'm right in thinking only the Fiio app, UAPP and Neutron allow direct to DAC bit perfect options? I'm not sure of the exact terminology.
No the alphabet scroll doesn't appear. It appeared with prior versions, and also appears my cellphone versions of Fiio music. I don't like the alphabet anyhow. It moves the graphics over when it appears which is not aesthetic, and also it's useless to me as i number all my albumsDear friend,
Best regards
Ok, thanksPoweramp bypasses Android but has it’s one resampling driver, even on DAPs with DTA
Yes, without M11 support (which it does have) it resamples everything to 16/44.1 or 16/48. With M11 support it resamples up to 24/384, but generally keeps it the same as your source files. Poweramp doesn’t do bitperfect in the true sense of the word. FiiO claims all third party apps avoid Android SRC on the M11 but that’s not been my experience. Regardless, I find FiiO Music to sound the best. Some people need crazy levels of EQ, which I’ve just never seen the point of (rather buy a more suitable IEM).Ok, thanks- what does this mean? It forces resampling or...?
Dear friend,No the alphabet scroll doesn't appear. It appeared with prior versions, and also appears my cellphone versions of Fiio music. I don't like the alphabet anyhow. It moves the graphics over when it appears which is not aesthetic, and also it's useless to me as i number all my albums- a scroll bar solves all problems, imho
If this is true, the M11 is pumping >1W power into the balanced FH7! Awesomehttps://www.head-fi.org/threads/dx1...s-zx300-private-meaurement-from-weibo.916092/
the guy hasnt revealed which is which yet but some people there pretty much confirm :
A-dx160 B-M6 C-M11 D-R5 E-ZX300
Mine works just fine (alphabet bar appears when you scroll, and doesn’t push the albums sideways).Yes sure. this one:
Dear friend,
Please enter settings-apps-fiio music app-store -clear data. Then restart the FiiO Music APP and check again?
Best regards
I find the M11 is so fast, a few flicks of the finger and I can go from the first to last alums in a flash. Then again I also categorize my albums alphabetically by album artist, so really can’t wait for that feature to be supported! @FiiOThanks.
I actually prefer the A-Z not appearing, as it's a useless distraction given my numbering system used to name albums. Now... a scroll bar... that would be useful![]()
Yes it does. Change the offline storage location in the Tidal app.Does the M11 allow you to download Tidal offline to the SD card? I’m primarily using it with Tidal? Can’t find info on this doing the search. Thx.
