FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
441 442 443 444 445 446 447 448 449 450
452 453 454 455 456 457 458 459 460 461
  1. Dmitry89
    If embedded, they should be displayed.
  2. Airsculpture
    Exactly , what I said. I believe his artwork is embedded hence the mystery.
  3. FiiO
    Dear friend,
    When connecting to some Bluetooth devices like our BTR3, the volume adjustment is not synchronous, unlike when connecting to a ios device. But at the same time, you could get more levels for controling the volume in order to receive better output volume you need.
    If the original volume of your M11 is 60 before connecting to a Bluetooth device, the volume will keep same(60) after disconnecting the Bluetooth device even if you adjust the volume to 120 when connecting to a Bluetooth device.
    And the volume of the M11 will turn to 120 when connecting to the Bluetooth device again.
    (Edited)
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
    DjBobby likes this.
  4. FiiO
    Dear friend,
    Thanks for the feedback. We will report to the engineer for assessing about that.
    Best regards
  5. FiiO
    Dear friend,
    I failed to reproduce the issue you mentioned.
    When the problem happens again, click the model number option from settings-about device for several time until ‘have save output log’showing up.
    Please send the files'M11-kernel-xx.log,M11-system-xx.log' from the root directory of the M11 to us for check.
    Best regards
  6. salla45
    Hi Guys and @FiiO . Can anyone figure out how that odd new target icon works in album view which replaced the A-Z bar? It seems to be intended to "go to top" but for me it doesn't quite get there, stopping at a couple of screens' worth of albums down the list. It's a pretty crappy addition, TBH :frowning2:
    Is there anything wrong with a sidebar scroll slider? That would be just so cool and normal
    thanks for considering
  7. exitfire401
    The target icon takes you wherever the currently playing track is located. If you're looking for the a-z bar in your track list screen, you just need to change the sorting to first letter, and it will return.
    salla45 likes this.
  8. salla45
    Haha. Ok, do i feel stupid? Lol. That makes sense now. Thanks.
    Still would love to have a slider bar though :)
  9. exitfire401
    Yeah, I wish there was a standard slider bar too, but it's an extremely minimal complaint from me.
  10. salla45
    yes it seems minimal, but with 2 x 1tb cards, that's a LOT of scrolling, potentially.
    navigation is a big issue with these apps when there's a lot of data involved, and as we're pretty scuppered to using the FIIO app apart from The Marmite (Neutron) for critical listening, it should be as easy to navigate as possible.
    @FiiO PLEASE NOTE ABOVE.
    2 customers are requesting a slider to navigate in album tile view. Thanks.
    exitfire401 likes this.
  11. exitfire401
    Haha, it's bad enough with 2 512GB cards...please don't make me think of the torture with anything more
    salla45 likes this.
  12. Airsculpture
    Unfamiliar with Android, which folder stores the wallpapers ? Ones I have downloaded are not in downloads or in the Pictures folder.
  13. Airsculpture
    Power amp works pretty well. UI is smoother than Hiby and the EQ is better than the FiiO app imho.
    SoundChoice likes this.
  14. salla45
    Yes I like Power Amp, and indeed have it also installed on the M11, but it's working via Android framework; not using the DAC directly, as I understand.
    I think I'm right in thinking only the Fiio app, UAPP and Neutron allow direct to DAC bit perfect options? I'm not sure of the exact terminology.
  15. FiiO
    Dear friend,
    Could you please tell me which page are you talking about ?
    upload_2019-9-30_14-33-1.png This one? Or that one? upload_2019-9-30_14-33-27.png
    Best regards
