salla45
- Mar 12, 2014
200 Hours.
You sure? I read it's optimal at around 1000 hours burn-in followed by a rapid decline in performance to coincide with the M15 pro+++ release
200 Hours.
@FiiO / @WianFiiO - I found a little issue with option 'Play through folder' - when this option is on, and for example I select a last track (give it a name A1) of a last album of artist A, when the track ends, player plays first track (give it a name B1) of first album from artist B (next artist after artist A). So, after selecting track A1 and opening Now Playing (as far as I found, opening Now Playing screen is not needed to force this issue), when the track A1 ends, track B1 is playing. The issue is: when you goes back one screen (should be track list of album B), the tracklist of album A is opened and track A1 (last of A's last album) is marked as a now playing track (floating bars on a cover miniature). When Now Playing screen is not opened after selecting A1 track, when track A1 ends and track B1 is started to play - still tracklist of album A is visible and track A1 (last of A's last album) is marked as a now playing track.
weird. Try messing with different chargers and cables. My X7ii is sensitive to that too.Yes, mine has starting charging again but all is not right as it goes through weird blue screen phase before coming on and also when you put in the USB power it does not immediately show the charging icon. I will try a factory reset I suppose.
I'm sorry if it's been mentioned but has anyone else gotten fed up with the scrolling function wherein the letters on the edge show up when I start to scroll but seem to disappear too quickly as I try to jump down from, say, "B" to "S", and end up touching an album I didn't intend.
Plus the constant changing of the album art size to compensate for the letter bar is just visually irritating..?
It didn't do this before the last firmware update so I'm hoping a new one will correct it?
In latest beta letters bar is now floating, in the same place with the same amount of time, but it is not causing those irritating movements of list interface. You can find it on I believe last 10 pages or more/less, and you need to sideload it from internal memory / sd card.
Hi,here is the latest beta firmware, you can download here :http://fiio-file.fiio.net/M11-ota-20190904.zip
200 Hours.
200? Really Ok time to burn in. Not to impressed with the sound so far hoping some burn in will open it up and improve it for me.
What does Fiio say on this topic? Burn in or not?
Here it is
Hi to all,
I bought the M11 and I have the following question, if the battery of M11 dies it will be possible somehow to replace the battery with new one?
