[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
SBranson
In latest beta letters bar is now floating, in the same place with the same amount of time, but it is not causing those irritating movements of list interface. You can find it on I believe last 10 pages or more/less, and you need to sideload it from internal memory / sd card.
I got the file.. I can't figure out how to install it. I put it on the SD card, went to technical support, chose local, and went to the folder but it just shows other folders until a dead end..
I am not very good at this kind of stuff ... to old and not too savvy .. maybe I should just wait for the "update for dummies" version that should be out next week?
Also does anyone know how I can install UAPP on my M11? I bought it for my LGv30 but without the google play store, I can't get it. I read something about an apk file but again.. too stupid to know how to get it or install it
UAPP cannot be installed on M11. The license of this application is activated only through the Play Market.I got the file.. I can't figure out how to install it. I put it on the SD card, went to technical support, chose local, and went to the folder but it just shows other folders until a dead end..
SBranson
That's a shame... thanks.
I know.. himself wanted to establish UAPP. However, if you listen only to music, then Fiio Music for this purpose is perfect, if you do not take into account the non-working equalizer.That's a shame... thanks.
totozero53
- Oct 26, 2009
Yeah, basically you’re SOL for UAPP.
As for the firmware you got the correct steps but did you unzip it before putting it on the SD card ? You should see the file that way.
SBranson
I did unzip it but put the whole folder on the sd card. Was there a specific file to put on there instead?
It shows the following folders
M11-ota-20190904
META-INF
com
android/google
but each folder just has the folders in them, nothing specific
Maybe I'l try again...
totozero53
- Oct 26, 2009
Sorry I checked, actually it’s the other way around, DO NOT unzip it and run it straight away from the firmware update app.
SBranson
Thanks... I'll try that..
** There we go... it's working now.. Thanks!
totozero53
- Oct 26, 2009
You’re welcome.
Now you can remove widgets from the dashboard !
arftech
- Dec 3, 2010
I am looking to purchase the M11 but have a few questions. How do I get access to Tidal and is it fully functional with it such as utilizing MQA? I mostly use IOS and is wondering how easy is the Android learning curve? How easy is it to transfer files from my Mac? How are you guys and women enjoying using this DAP? How are y’all enjoying the sound quality and does it compare favorably to some of the elite DAPs on the market? This seems to be quite the player judging by some of the reviews.
arftech
- Dec 3, 2010
Placed the M11 in my Amazon cart and hit buy. BTW, I chose the option for the bundle which included a 32G card and some IEMs priced at the same level if you bought the M11 alone. Interesting.
officerdibble
Probably a dumb question.....
Can I add an album to the now playing queue in the fiio app?
A regular playing queue is not available (you are not able to add for example all album to play when current music queue goes to the end, you only can replace current queue) on M11. But yes, you can. When you open desired album, on top left of the tracklist there is a icon with lines and little play symbol. Press it and all visible under it tracks will be added to now playing queue.
officerdibble
Cool, thanks! I'll give it a go.
