FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
420 421 422 423 424 425 426 427 428 429
431 432 433 434 435 436 437 438 439 440
  1. SoundChoice
    The M13 will have no SD card slots, one-hour battery life and the balanced output will operate with a hand-crank.
  2. JukeBoxJimmy
    Really disappointed about only one SD slot in the M11 Pro. I have the X5-3, X7-2 and M11 and never hade issues with dual SD slots. My M11 even has 1TB in each slot. People who have had problems most likely use low quality SD cards....................Jim
    CactusPete23 likes this.
  3. FiiO
    Dear friend,
    The balanced output power in this form is for trial production version. In official version, the balanced output power is 550mW. The battery capacity of M11pro is 4370mA while M11 is 3800mA instead. However, the DAC chip AK4497 takes more power so the battery life of M11pro is shorter .
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  4. alvinlim2010
    I guess it is a compromise between having good battery life and having access to the THX chip...unless sound quality is going to be a huge improvement, does not seem to be a worthy upgrade if you already have a M11.
    CactoesGel likes this.
  5. x X x
    Hello,
    I have a SanDisk 128 GB usb drive (it is a combo drive with normal usb connector and usb c), and I am unable to mount it to Fiio M11. It shows me that mount is failed, and only way to "fix" it is to format it. Format is completed, but mount is still failed. This usb drive works well on my OnePlus 6, or other devices. Any sugesstions? Fiio, please help. Could be some issue with software? Or OTG memory devices are not supported by M11?
  6. gLer
    I’ve had similar issues. Can’t get any OTG drives to work.
  7. x X x
    @WianFiiO and @FiiO, please check this issue. I've bought this stick especially for moving music from / to my M11 and I am unable to do this due to this issue.
  8. FiiO
    Dear friend,
    Do you want to connect the u disk to the M11?
    Best regards
  9. x X x
    Yes I do. Device sees my disk but cannot mount it. After connecting usb device to M11, notification appears with text:
    Mount failed SanDisk USB drive
    SanDisk USB drive is mount failed. Tap to fix.
    After opening this notification there is a screen with information, that my drive needs to be formated as portable storage. After pressing button Erase & Format, screen with information that format is in progress appears, and when format is done (?), screen with information that SanDisk USB drive is ready. In this moment, mentioned notification appears again.
    I tryies to format my device on a Windows 10 to NTFS format, but device is still not available on M11. There is also exFAT format, but as far as I know it is not supported by Android.
  10. Storyline
    Yes, mine has starting charging again but all is not right as it goes through weird blue screen phase before coming on and also when you put in the USB power it does not immediately show the charging icon. I will try a factory reset I suppose.
  11. Storyline
    I am not an expert but I think the M11 will only take the current it wants and just because the charger is rated higher it doesn't mean it will force that power into it.
    I stand to be corrected though :wink:
    Paul
    Jujoe likes this.
  12. Jujoe
    Totally right buddy I just like to play it safe :)
    Storyline likes this.
  13. studiorat67
    Hello
    I have an issue with My M11
    Lately its been connected to a Fiio E18Kunlun and when I power off and shut down the M11 Reboots and is in a Bootloop until I hold power and Play and then It boots into the Player, But When I'm Not plugged into the Kunlun via USB it powers off, I assume it's the Amp..... What if any are my Options, Fiio can't answer because they are on Holiday...... Anyone here have issues with this
  14. Shawnb
    Does the M11 require any sort of burn in and if so how long?
  15. gLer
    No it does not.
