Any way I can get the fiio music app to scan all the music on my card? It will only scan new music I add to card. The hibby app scans everything on the card whenever I turn on scan operation. For some reason hIbby shows 70 more tracks on my card than Fiio does. I want to force the Fiio to scan everything on the M11. Thanks
I take it you didn’t install the beta firmware posted on this thread that apparently eliminates this problem?
No, I avoid prototype software whenever possible, and hadn't experienced the problem before today. Good to know it's there if it recurs enough to drive me to it though. So this is thought to havea fix then?
And presumably the fix will come in the form of what, 1.0.7? An upgrade to Tidal app? I wasn't using the FiiO player.
sorry but Im a total newbie to DAPS. Is there a setting called reset the database that I click on and do I need to remove my card when I do this so it doesn't erase all my music? Thanks
There's a setting in FiiO Music settings that allows you to reset the database. Don't stress, it just erases the music database from FiiO Music, not actual files from your cards. Once done, just initiate a rescan of all your cards, and in minutes everything will be up to date.
Resetting database worked very well. I thought I was going to have to format my card and drag 5 thousand songs back into the card. Thanks again.
The M11 is so fast, it’s easy just to reset and rescan. Still hoping for a major FiiO Music overhaul to make simple stuff like real-time library updates more straightforward.
Did anyone try installing Aurora Store instead of Google Play Store? I am generally moving away from using Google's monopolizing services, and found Aurora Store useful in transition period and I'm trying to mostly use F-Droid with open source software. I'm thinking about buying my first DAP and I'm just generally curious about it. Hopefully that would help some of y'all that have issue with missing Google services in case it works.
Yes it works great but obviously it doesn't allow apps like uapp to authnticate licenses through google services. I prefer not having all the google bloat garbage on my dap. But I prefer Neutron anyway bought direct through paypro and Aurora updates it fine and keeps the paypro license intact.
So I guess someone is going to have to test the new Amazon HD on the Fiio. Very intrigued to read impressions! Anyone even tried it yet?
Will the M11 be able to adequately drive the Hifiman Sundara? Has anyone tried, or any knowledge about this?
Were you using a balanced output? @FiiO when is this going to be fixed? Its a risk to damaging someone’s hearing as well as their headphones. The fact that you haven't acknowledged the problem is also troubling.
