FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
419 420 421 422 423 424 425 426 427 428
430 431 432 433 434 435 436 437 438 439
  1. gLer
    The bull’s eye icon means there’s a balanced cable plugged in. It only comes on when the M11 is in balanced on. If you’re plugging a 3.5mm cable into the 3.5mm cable port (the one on the opposite end from the two balanced ports), then it means your M11 is stuck in balanced mode and you won’t get any sound out of your 3.5mm port. In which case, you should return your M11 and get another one. Since yours is the only M11 that’s been reported with this problem out of many thousands sold, I’d say it’s a once-off case. Return it and have it replaced.
  2. sabloke
    Thanks for the advice. That's exactly what I'm going to do. looks like one of the balanced ports is stuck, not sure if the fault is hardware or software. I'l RMA its arse this week. :)
  3. x X x
    Try restore your device from recovery mode. When it is turned off, press and hold power and next track button till you see Android Recovery screen. When it is onn, navigate (witch volume scroll) to 'Wipde data/factory reset (confirm with power button) and confirm wipe by selecting yes and pressing power button.After reseting, your player should go back to main menu of Anrdoid Recovery. If not, go back and select 'Reboot system now'.
    Your issue looks more that faulty unit issue instead of software problem, but let's try this :wink: Hope you can fix it in this way.
  4. magina35
    Thanks for the detailed reply! Will try those settings with mine :)
  5. Dmitry89
    I heard about such a problem with other devices. You can try to clean the balanced connector, maybe it has a foreign object (it helped one guy). It is unlikely that this is a software problem, most likely this is a defective product. Send for repairs with a valid warranty card.
  6. cbl117
    Has the extremely loud static noise when resuming playback in sleep mode been resolved?? Can anyone confirm if this is an issue with balanced output only?
  7. keithmarsh
    I haven’t had too much time to thoroughly test, but for me that latest beta seems to have fixed the issue (and I was experiencing it a lot).
    good work @JamesFiiO & team :)
    In my experience it only effected balanced output.
    Jujoe likes this.
  8. cbl117
    That’s good to hear! @JamesFiiO do you know when the new firmware will complete beta testing?
  9. WianFiiO
    Hi, we may release the offical version in next week if everything goes well.
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
    Vitandus and x X x like this.
  10. FiiO
    Dear friend,
    Thanks for the feedback.
    Hope that problem will be sloved soon. Sorry for bringing inconvenience to u. If you have any problem still, please feel free to contact us.
    Best regards
  11. FiiO
  12. Dmitry89
    gLer likes this.
  13. gLer
    Agreed - a subtle SQ upgrade won’t be enough to compensate for the loss in power, battery life and extra SD slot.
    Jujoe, simon740 and Dmitry89 like this.
  14. Jujoe
    HOOOOOOOOLD :p M15 incoming in 6 months
  15. exitfire401
    Agreed...really odd choices on this one
    Mybutthurts likes this.
