[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
JimBob85
- May 9, 2009
@JamesFiiO Hi James, are we able to get root access to the device so we can install Viper4Android? Being an enthusiasts device, it would be great if you provided us with more control over our device
audiophilefan
- Jul 1, 2015
The FiiO case arrived today
Sleek. How's the overall fit vs the stock case? Is it not loose so as to avoid lindt from getting inside it (though I imagine this would be normal for any case)?
How about buttons, still easy to navigate and press?
It's a little loose at the top. The buttons are definitely clickable. It feels better than I thought it would.
That’s because DVC (Direct Volume Control) is enabled by default. You need to go into settings - audio - output (or something similar, can’t recall exactly) and disable DVC for your output type. You also need to disable headroom limiter for DVC. Once that’s done Poweramp will play at the same volume level as FiiO Music. A bit confusing, I know, and not exactly initiative, but Poweramp is like a spaceship in terms of tweaking and features compared to the bicycle that is FiiO Music.I had to uninstall Poweramp. I couldn't figure it out. It sounded terrible. Very strange.
audiophilefan
- Jul 1, 2015
Thanks! I'll probably order one when it becomes available locally.
we will not suggest you do that cause there may have unexpected problem.
BTW, Plz post your suggestion or any question to the following thread in case I have not notice it .
https://www.head-fi.org/threads/the...-plans丨product-functions-and-features.903431/
abitdeef
Formerly known as ihatepopupads
- Oct 30, 2003
Definitely looks better.
abitdeef
- Oct 30, 2003
Bicycle! bicycle, I want to ride my bi cy cle, I want to ride my bike. I want to ride my bi cy cle, I want to ride it where I like....
Lol Freddy, one of a kind.
jmills8
Previously known as bmiamihk, jmills2
Nice, seen them live three times.Bicycle! bicycle, I want to ride my bi cy cle, I want to ride my bike. I want to ride my bi cy cle, I want to ride it where I like....
abitdeef
- Oct 30, 2003
Twice here, very good shows! Gotta say album art just looks lovely on the m11's screen- it pops! As they say.
Jujoe
jmills8
Try : Scandal, The White Queen, Calling all Boys.DAMN YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Now I'm on a Queen session
SOMEBODY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! TO LOVE
Juj
Jujoe
To be honest I'm all about them fat bottom girls
Juj
Total: 12 (members: 0, guests: 12)
