Ok the volume wheel is getting annoying. Is there a way to have the screen volume to pop up without using the wheel?
Also why are people having so much hate on 2.5mm? Has anyone have had problems with it?
My engineer side tells to like 4.4mm but I have never had a problem with the 2.5mm.
I don't think 2.5 breaks easily. And it sounds wonderful, don't worry about that. I never had a problem either.
About the wheel, what's wrong? I guess you can download some app to ease your access to the volume. It would be good if FiiO adds the possibility to customize the buttons anyways (or maybe it exists already?) so we can choose between volume / skip or even disable them completely.
