[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Jun 9, 2019 at 7:40 PM Post #2,522 of 9,288
was seeing all options i could do to make it loud enough
Only thing you can do is turn up m11 all the way, or use ldac. I've got these cheapie Sony wireless buds and they get loud! Not as loud as the amp in the dap, it never is unless you use a good bluetooth dongle, well it will get as loud as the 3.5 in low gain but otherwise it depends on the built in amp of the speaker or headphones.
The bluetooth protocol makes a difference also.
Jun 9, 2019 at 9:38 PM Post #2,523 of 9,288
Anyone had any luck with wireless transfer of music to M11 using iTunes on an iMac? I brought up the transfer screen but when I try to drag and drop songs into the square where it says to do it, nothing happens. Im on same strong network as the computer with the M11 but no luck. Do you need to have the MTP driver installed in the iMac to make this work?
Jun 9, 2019 at 9:44 PM Post #2,524 of 9,288
Well, I cleared and reset the device and all seems fine now. I guess fiddling with apps and such caused a glitch in balanced out. Hoping this doesn't happen again!
Ok, a follow up to my earlier problem.
It appears that when I have the M11 connected to USB port of my desktop PC (Dell Optiplex) and I play through the balanced port (2.5 or 4.4) from muted condition (after 15sec power down), I get a very loud buzz when I start to play again. The attached ZIP https://www.dropbox.com/s/4w0rk8gbjx29b7y/M11 Noise .m4a?dl=0 captures the noise heard (volume warning! It's very annoying!).
If I unplug the USB the noise goes away. The problem does not seem to happen on 3.5mm port.
Any similar experience or guidance with this? It's not a ground loop hum. Maybe some ground isolation issue?
Jun 9, 2019 at 10:14 PM Post #2,525 of 9,288
Has anyone found a document explaining all the different options settings? I don't know much about all the different modes and stuff...enter technical jargon here.
Jun 9, 2019 at 10:35 PM Post #2,526 of 9,288
I haven't tried to contact the M11 to my mac yet.
Just used a Micro SD card i already had.
But with other Android based daps i usually use the free ‘Android file transfer’ app (for mac)
Jun 9, 2019 at 10:58 PM Post #2,527 of 9,288
I thought this player had access to the full Android app store. Is this true? All I can find is the list of FiiO recommended applications, mostly other music apps. (This is my first real Android device, still figuring things out)
Jun 9, 2019 at 11:02 PM Post #2,528 of 9,288
Rocking out!
Jun 9, 2019 at 11:31 PM Post #2,530 of 9,288
Below that list is other apps. And apkpure is one of them, you can use that to download and install other apps.
Jun 10, 2019 at 12:33 AM Post #2,531 of 9,288
I know this is totally OT but you informed gentlemen would know the fastest (reliable) microSD card read.. kindly enlighten me please!
Jun 10, 2019 at 2:09 AM Post #2,532 of 9,288
Since then, I've swapped the stock silicon tips of the XBA N3 for a Silicon/Foam hybrids. The foam seem to have helped bring the bass a bit forward and specially helped tame the high frequencies that were literally killing me.
So far I'm more pleased with the change. i also have some comply tips that bring the bass even more forward at the cost of being a hint boomy, but let's see how it goes with these hybrids.
Yep, sounds like it’s definitely your IEMs, not the M11, although the tuning of the M11 will also determine how IEMs respond to it.
Jun 10, 2019 at 2:09 AM Post #2,533 of 9,288
I had M5s and as I mentioned earlier, the shanling is warmer sounding and the stage is bigger on m11. Honestly the m5s sound didn't compare to my sr15/,zx300 in the fact that the treble was too soft. It sounded nice, it just didn't do it for me.
The m11 wowed me immediately, probably because I like a more neutral detailed treble sound. So in a nutshell, me I personally liked the m11's sound better.
MUCH appreciated for the info and the opinion bro :)
Jun 10, 2019 at 2:28 AM Post #2,534 of 9,288
Mega reply incoming...
I was testing how different Bluetooth codecs sound by using two DAPs, and found that some DAPs were sending a lower volume level over BT than others. I'm not sure what is up with that either, but I'm going to test everything I have and see what I can nail down.
Something I did find is that even if the M11 and other DAPs are set to output LDAC, that doesn't mean that they will. If the receiving device can't do LDAC then you'll usually get SBC, or APTx if you're lucky. Since a lot of headphones don't indicate what codec they are receiving it's luck of the draw.
Yeah M11 def sounds best balanced in high-gain. I’m averaging Vol 40 on the FH5 with these settings.
It's worth noting how extremely easy it is to be fooled by gain settings. Even a 1dB increase in volume can sound better when comparing two things, so it is easy to think that higher gain settings sound better, when really they are identical in performance. This still gets me from time-to-time as the illusion is very convincing.
How's the M11 sound when used wirelessly? I assume it'd depend on whatever headphones you have since it's using whatever DAC is in there instead the one in the M11
Someone already answered this, but since it comes up often, a Bluetooth transmitter doesn't have a "sound" as it is only transmitting digital. The only way this can be changed transmitting digital audio is by changing between SBC, AAC, APTx and LDAC essentially, which use different (lossy) compression schemes to send the audio.
Fiio have said they are stopping with amp modules soon. Maybe they'll go the Cayin n6ii route
$200/amp module certainly wasn't appealing.
I reckon you have something wrong with your M11. Mine is dead silent. As in pitch black. I auditioned the notoriously sensitive Andromedas last weekend and try as I may, high gain full volume (no load), SE and balanced, quiet songs, loud songs - zero hiss. Not even a faint whisper. This thing is black.
Dead silent while tracks are playing? Some super-sensitive IEMs will still pick up hiss, but this only during silent parts during music. I should really make a file of silence to test hiss.
Early in the thread some people we talking about standby life of the battery, I found that 4% draind off in 10 hours in standby.
I read in the audio options that ALL TO DSD will drain it much faster up to 50%. I have yet to try leaving it in that mode over night in standby but I'll test tonight.
I suspect some apps, after being run, keep processing in the background, causing the battery to drain faster even when not playing. I should have tested DSD battery performance, now I think of it.
After a day testing, I'm really not sure what to think of the sound signature. This is with my Sony XBA N3.
Too clynical maybe, too sharp.
Maybe I'm too used to a bit warmer sounding, tho "lower end" daps. Currently I own a FiiO X3, Walkman A35 and Cayin N3. All entry level daps, and all of them sound engaging and inviting.
This one feels impersonal, I didn't get any wow factor the second I put it on. The imaging is the only thing I really feel is an upgrade, it is more progressive, more coherent, specially in the middle. Is not that I found the player technically flawed, on the contrary, is quite too perfect maybe? Not organic.
Now I'm thinking maybe a ZX300 is more my cup of tea, if it retains that "Sony" sound.
I'm gonna let this one grow on me before I take a decision
Some DAPs seem to be tuned a bit warm, deliberately. I find the FiiO sound to be a too perfect for my tastes too. Something you can try is changing the digital filter to one of the slow ones. You might like them better.
Yes, here: https://www.head-fi.org/threads/the-all-in-one-thread-to-address-any-inquiries-to-fiio-product-lineup-丨future-plans丨product-functions-and-features.903431/page-5#post-14997390
THX AAA is some sort of voodoo amping tech from the movie sound company THX (hence the name) that’s meant to make for exceptionally clean, transparent, noise-free playback. How that will be implemented in dap form, we’ll have to wait and see.
If it lives up to the potential and improves on the sound quality of the M11 at a price tag of ~$800-$900, the flagship daps will be in serious trouble.
The THX amp module might be a good match with the X7II. I found that its DAC performance exceeded that of the amp modules like the AM3A, so if the THX module is an upgrade, then that's a good thing. I should test the M11's DAC performance. I forgot to do that.
You are a funny guy!
You should learn some better manners for posting online, as you aren't helping anyone with your aggressive, and sometimes rude comments. You could have posted the same comments in a way that was helpful and had more effect. I suggest if you cannot write a post without being aggressive and rude, that you don't post at all, nor even come to this forum any more.
I'm not one for fancy talk, I've bought 13 daps in the past 6 months this is the only one to not go back. It sounds good and doesn't piss me off when trying to use it.
Please DO list them (maybe it'd make for a good, separate thread) and explain, briefly, all the things you didn't like about the DAPs you bought. You might cop a bit of flak for your comments, but I (and other people) find "journey" threads to be interesting.
Cant figure out the album art. I have a 64gb Sandisk card with about 4 thousand songs, all connected to album art.When I play random songs they do arrive with the album art on screen but when I go to fiio app to look at my album art only the first 50 or so appear and the rest don't as I scroll through albums.I know the art is there but it doesn't all show up as I scroll. My card is in SD slot one, should I switch it to slot 2 and try to rescan the card. The same card was used in the M3K and all album art appeared with no problem.
I have over 1k songs and no problem with embedded album art. I find the art only shows up after the scrolling stops. Someone suggested to me getting a Sandisk Extreme or similar for better performance. I'm guessing the FiiO music app doesn't cache the art.
So im getting tired of dragging and dropping songs from my tunes account on my iMac to the card .Looking for a quick way to just sync my 90GB of music from my iMac iTunes into a 128GB card in my m11 just the way its effortlessly done using an iPod with one sync push of button. Does the Android software Fiio talks about on their site or the wireless adding of music allow this effortless sync? Would hate to have to buy software to make syncing work. Thanks for your help.
I use rsync in the terminal. Years ago, I wrote a guide how to sync an AK100, which required changing the format of playlists. If you know what you are doing, you can put an SD card in your computer and use an exported iTunes M3U playlist in rsync to copy the files in it with one command. More or less, it's steps 1-4 in that guide. Other than that, I think Syncmate will sync files. I haven't tried it for a while, so I'll give it a go to see if it works.
Unless you're using it as a USB DAC I'd just not connect it to the DELL. Ground isolation issues come through as a low hum. This is one for FiiO to figure out I think.
I basically tell people, if you don't know what it does, you don't need to know. I went through some of them in my video review, but are there particular options you are wondering about?
Sandisk Extreme.
