FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
161 162 163 164 165 166 167 168 169 170
172 173 174 175 176 177 178 179 180 181
  1. Ojisan
    Thanks for checking! From the sound of it, I have a feeling it's a digital line (USB data) coupling into audio out. Power (DC) or static noise don't produce noise like that.
  2. fatmanny
    Does the Fiio app support m4a files? It's not recognizing them when I scan the folder they're located in.
  3. fatmanny
    Also, is there a way to have album artwork show up as the artist artwork in Poweramp?
  4. DrKrFfXx
    Yeah, I came across you on the other thread.
    I find the Sony Hybrids slightly sonically better than Complys TS200. and confort wise rather similar. The Complys blockbso much more noise tho.
  5. Ojisan
    I have some albums in m4a on my SD card and they show up fine in the FiiO player.
  6. Jujoe
    Hope this helps.
    Juj
    Currawong and mattg3 like this.
  7. mattg3
    Thanks
  8. Jujoe
    art.png These are the settings I save to player with.
    Hope it helps.
    Juj
  9. cleg
    abitdeef, ExpatinJapan and jaxz like this.
  10. Jujoe
    hahaahahahaha if it costs more it must be better.
    well thats my review of your rerview.
    Juj
  11. mattg3
    [QUSoOTE="Jujoe, post: 15001096, member: 506890"]I sync via musicbee and use these settings for saving artwork. [​IMG][/QUOTE] Thanks,So did you put musicbee right into the M11? Im so new to this that I cant figure out how to get it. Its not listed under applications on the M11.
  12. Jujoe
    Thanks,So did you put musicbee right into the M11? Im so new to this that I cant figure out how to get it. Its not listed under applications on the M11.[/QUOTE]
    I have musicbee on pc, then when I connect M11 to pc I open musicbee and select device on the left.
    Then pick playlist I'd like to sync.
    Then once snyc is finished just scan for music on the M11.
    Phone is used in pics as I am blasting Daft punk on M11 :)
    Hope This helps.
    Juj
    mattg3 likes this.
  13. Leetransform25
    Can everyone just give this guy's message a like for spending this much effort mass addressing 14 posts at once
  14. Jujoe
    Leetransform25 likes this.
  15. Leetransform25
    If you don't care about the things that make a DAP an audiophile product and only give a damn about Bluetooth, I have the perfect device for you.
    An Android phone. And yes, it has that LDAC you seem to love so much, as well as gapless/replaygain/whatever else you want if you have the right app. Really not sure why you decided to get an M11 if you're just going to strictly use Bluetooth.
