FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
post-14994223
Post #2,191 of 8,324
aaf evo
Houston, TX
Houston, TX
James/fiio where can I get an official front screen protector? The fingerprints are causing me high anxiety. If you can't sell them or send me one, can you at least tell me the brand?
I'd hate to buy one and still have the fingerprint problem.
Did yours not come with one pre installed on the front and back?
post-14994242
Post #2,192 of 8,324
jmills8
Previously known as bmiamihk
Hong Kong and Miami
Hong Kong and Miami
Ocd = hobby
Reactions: abitdeef
post-14994252
Post #2,193 of 8,324
abitdeef
Formerly known as ihatepopupads
Yes, but the one on the front constantly fogged up on the far right side and I kept trying to wipe it off. I think it just wasn't seated properly on that side. It looked like the alphabet strip was constantly dirty. Weird I know.
Anyways I took it off and tried to clean it and reapply it but.... it didn't work so good. So now I have the bare screen which is like getting your fingerprints printed at the pokey after being arrested every time you touch it.
Ok I'm exaggerating, but it's much worse than the screen protector.
post-14994255
Post #2,194 of 8,324
abitdeef
Ocd = hobby
Yes I'm neurotic. But it would be nice if fiio would take 2 seconds and answer :wink: I will contact their CS. I just thought since James pops in now and then he could answer one way or another.
There are 2 on Ali Express, but no ratings yet and I'm not sure if they're anti fingerprint. I've used stuff that's supposed to have an oleophobic coating that was horrible for getting fingerprinted up.
Reactions: jmills8
post-14994263
Post #2,195 of 8,324
jmills8
Hong Kong and Miami
Hong Kong and Miami
post-14994321
Post #2,196 of 8,324
Caguioa
how do u connect bluetooth devices headphones to m11?
my iphone can still pick it up, even after i disconnected from my iphone, and yes my m11 is connectec to wifi
says fiio m11 is visible to devices while bluetooth settings is open..
i even tried using my iphone, it works with bluetooth devices perfectly
but when i connect my m11 to my iphone...
there no audipo
iphone>connect bluetooth> M11 connects to iphone doesnt work...
bluetooth on my iphone says its not coonected..but i literally click on "pair" both devices with same code
post-14994346
Post #2,197 of 8,324
Caguioa
ok it took minute to pair but on my M11 it says
"Sbc"
"BT SINK Mode"'
and thats it
both are now connected via bluetooth on my iphone
headphones - connected
Fiio M11- connected
is that how it works?
post-14994351
Post #2,198 of 8,324
Jujoe
Purgatory Hill
Purgatory Hill
there no audipo
Sorry are you having issue with just your Iphone or all bluetooth devices?
If its just the Iphone sorry I have no device, however if its other devices I have had no issue at all connected to LG tv, Denon AVR, Sony phone and an old bluetooth headset.
If its all devices get a replacement.
Hope this helps.
Juj
post-14994440
Post #2,200 of 8,324
Jujoe
Purgatory Hill
Purgatory Hill
Anyone try LO for line out. My M11 has low volume and very distorted. Head phone mode works properly.
Jim
I line out to JDS labs Atom no issues with volume or distortion.
Juj
post-14994480
Post #2,201 of 8,324
abitdeef
Jim
I just tried mine in the old Rover aux in and it sounded fantastic- no distortion at at all and it cranks.
post-14994482
Post #2,202 of 8,324
Caguioa
Hope this helps.
Juj
i just want to connect my blue tooth device only to my m11, for all my songs inside the m11 and maybe when i have wifi for soundcloud etc
post-14994493
Post #2,203 of 8,324
Jujoe
Purgatory Hill
Purgatory Hill
Try to get the Iphone to forget the devices then pair fresh with the M11.
Hope this helps.
Juj
post-14994525
Post #2,204 of 8,324
gefellmics
Germany
Germany
Unfortunately I have no luck to install "USB-Audio Player Pro" with the Fiio M11. I would love to use the same player app from my LG G7 with the Fiio M11.
Any apk available for download?? All I find via google search are various cracked versions....
Thnaks for your help!
post-14994550
Post #2,205 of 8,324
JukeBoxJimmy
Got my return slip, its going back.
The odds caught up after buying 6 Fiio units, FH7 will arrive on weekend..................Jim
Users Who Are Viewing This Thread (Users: 2, Guests: 10)
