Not that I use youtube much but I did watch @Currawong review on the M11 chrome app and to get the video to rotate I just went full screen. There was no auto rotate also it stays rotated for some reson after you exit the video and as noted in the review the sync is out
Good indepth review, recomended viewing for anyone one the fence about buying an M11.
Yes, I pointed that out to @JamesFiiO way back when, even before my own review. I’ve since downloaded a screen rotation app, so problem (manually) solved. You can also just swipe back to home and portrait mode resumes. The lip sync issue I imagine is a harder fix... oddly there are no lip sync issues in Netflix, Plex etc.
Youtube Vanced is a modified official Youtube app. It gives possibility to login with your Google Account and having your subscriptions. Works great for me. Details below: https://www.xda-developers.com/youtube-vanced-apk/
I heard its better than Shure 846's
not sure if I should bite, vert interested in the FH7 but its like the "newest" iem flagship and seeing how shure846 have been out there for minute.
@FiiO , would it be possible to add airplane mode into it so as to try maximise batt life? This would help to ensure that BT and wifi would not be turned on.
So the M11 has no airplane mode and wifi is on all the time? That isn't good,Ill probably just use it for firmware updates and then delete my password since Im only using device for stored music on card. Wi fi must kill the battery.
What i meant was to include an airplane mode so that there wun be accidental activation of wifi and bt. Of coz for firmware updates, i will need to turn on wifi but it will usually be at home, with access to a charger.
Formerly known as ihatepopupads Headphoneus Supremus
James/fiio where can I get an official front screen protector? The fingerprints are causing me high anxiety. If you can't sell them or send me one, can you at least tell me the brand?
I'd hate to buy one and still have the fingerprint problem.
