[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
mattg3
- Dec 4, 2005
Just got my pre-ordered unit and gf took a product shot after loading the sd card.
So the album cover fills the whole screen! What setting gets that to happen?
Jujoe
Well after having this little beauty for a few hours I smitten with it. In comparison to the Hiby R6 (I had 2 fail on me) it feels like a big step up in all aspects except maybe the FiiO app but I also could just be a learning curve.
For my test I listen to :
Radiohead - Pyramid Song
Eric Clapton - Cocaine
Rage Against The Machine - Bulls On Parade
Philip Glass - Rubric
Atmophere - Shoulda Known
I went for a walk and used In ears these were the Denon AH-C700 and FiiO FH5, While at my desk the full size headphones I used were the Philips Fidelio x2 and Audeze LCD-2 Closed.
I found the M11 to playback on these without it altering the sound signature or giving any audible hiss.
I'm blowen away by the level of detail it can produce, Sorry for the ramble.
Juj
Juj
abitdeef
Formerly known as ihatepopupads
- Oct 30, 2003
Funny thing is I have MP3 sounding better or as good as DSD. I also had Flacs sounding worse than MP3s.
I think a lot depends on the way the albums mastered too. I mean that particular album sounds fantastic, even in mp3. A lot of my albums I ripped when 128kps was still viable, yes a long time ago....
lesale08
I think background was due to the spotify playing while the screen is lock. Not the native Fiio music app.So the album cover fills the whole screen! What setting gets that to happen?
Seeing you too have a xdp300r, I would really love to hear your thoughts on how do you think the M11 compares.Just got my pre-ordered unit and gf took a product shot after loading the sd card.
lesale08
I will give them a good side by side listen probably this weekend when I am not busy and have lots of time to listen to music. I will need to load the same test music files for better comparison results.Seeing you too have a xdp300r, I would really love to hear your thoughts on how do you think the M11 compares.
Sven2015
- Sep 15, 2015
I got my M11.
First impressions: WOW. What a heavyweight!
Second. It seems my problems with gapless playback / micro gaps gone with the M11 device. In addition it seems, M7 and M9 had not enough power / RAM to process a good playback streaming....
Third. The new internal +12dB EQ is okay in treble but I cannot see / hear great differences in setting the (sub) bass bands (similar to M7 & M9 - but there is just a gain of +6 dB max).
@FiiO
Can you check the EQ in (sub) bass, pls? Maybe there is a kind of limiter implemented for bass?
My Hidisz Ap080 makes much (much much) more bass (without any distortions).
LDAC HQ connect with Sony headphones (1000XM3)
@FiiO
jmills8
Previously known as bmiamihk, jmills2
They should add a Sub Woofer button.I got my M11.
@FiiO
@FiiO The Music app seems not to be able to deal with special characters in the tags and displays Chinese signs instead. This happens for example in the case of: “ ‘ , ä, ü, ø, “ etc.
Is there a solution and did anyone else notice this?
Sven2015
- Sep 15, 2015
I installed my preferred music app (gonemad player) now and there is a perfect +12 dB EQ with limiter and pre-gain.... and it's working perfect with the M11.They should add a Sub Woofer button.
AND there is a BALANCE control for BLUETOOTH devices!
fatmanny
Was there ever anything found out about Viper HiFi that's all in Chinese? What is it? Is there a plan to make it English?
Have you heard some differences in sound from m9, m7? Do you feel m11 worth upgrade from these ? ThanksI got my M11.
@FiiO
Sven2015
- Sep 15, 2015
micro gaps are gone and gapless playback is working fine....but I don't use the FiiO music app....now, I use my preferred music app.Have you heard some differences in sound from m9, m7? Do you feel m11 worth upgrade from these ? Thanks
I detect the internal EQ is not working so fine for me (in bass it's similar to the M7 / M9)....but in past I had the AP80 with a better internal EQ (graphic / parametric).... but you can use your preferred music app @M11.
The hardware of the M11 is very fine (no distortions or other problems detect). In my mind one of the best players....in my situation, the upgrade from M7 / M9 was perfect.
Thanks i think with m11 with many different apps to choose it's possible to tweak the sound much more than in restricted m7, m9. Heard viper efects if they work with m11 should be able to make more bass if needed. As i believe m11 not very strong in bass, more neutral. I am waiting my from china so when i get it i will surely try so tweak the sound.micro gaps are gone and gapless playback is working fine....but I don't use the FiiO music app....now, I use my preferred music app.
