FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
117 118 119 120 121 122 123 124 125 126
128 129 130 131 132 133 134 135 136 137
  1. Sven2015
    Today was release day @Germany. :)
    My pre-order sent from German FiiO shop today. "Fiio - a new chance" or "FiiO - the last chance"... :wink:
    Ryokan likes this.
  2. Sven2015
    Heah? ReplayGain prevent that if you tag your files for both - title and album gain. For a normal album you will set replay gain album. The gain is set for every album new or you select title gain....
    foobar2000 has a default value by 89dB for ReplayGain to prevent clipping. If you use that value for every title / album you will get the best result. :wink:
    btw. What's happened with LDAC connection? @another user. Do you found the correct setting now? M7 & M9 supports LDAC and in my mind M11 supports LDAC, too... but I hope is just a handling issue not a new gap of the latest FiiO model.....
    From the FiiO FAQ
    A: The M11 supports the HWA, LDAC, aptX-HD, aptX and SBC codec. The HWA codec needs to be switched in the FiiO Music settings, while the others can be switched in system Settings -> Audio ->Wireless playback quality. Also, kindly note that after switching the codec, you'll need to disconnect the Bluetooth and then reconnect to have the changes take effect.
    In my mind. BT connection is part of OS, not of an app such poweramp....
  3. Ryokan
    M11 on the way. Any tips before using, like having to set gapless playback?
    Any advice appreciated.
  4. ThomasHK
    @FiiO
    FiiO app on phone side does not report correct playback setting (shuffle/repeat/repeat 1/...) from the M11.
    By the way, is there a better way of sharing bugs? I don't want to keep flooding this thread.
  5. dissembled
    Guys, the M11 has disappeared from the M9 product page and I can’t find it on Amazon anywhere! What gives?
  6. mattg3
    Im getting my M11 tomorrow and Im going to burn it in for a few days like you did. Is there any special volume setting you set for this and did you connect IEMS or full headphones for this? When running it for 48 hours, did you plug it into a wall outlet for the run since I don't think a charged battery will last for that long? Thanks for your help.
  7. abitdeef
    I think gapless is on my default, but it's in the fiio app menu.
    Ryokan likes this.
  8. jaxz
    I Joined the club. Just ordered from aliexpress
    abitdeef likes this.
  9. pastorernie
    I used the Andromeda S on low gain, balanced, volume at 50, and the Ether 2, high gain at 100 out of 120, balanced, with a classical file of large dynamic range set on repeat, both about 50/50. Did the trick.
    mattg3 likes this.
  10. dissembled
    I already own the Shanling M5s so I wonder how similar the sonical properties of the M11 and the Shanling would be since they do have identical dacs. I plan on acquiring the M11 in the near future and hence my curiosity.
    How similar would the sound be would you guys wager?
  11. abitdeef
    I had the M5s, from memory the m11 sounds more neutral with a bigger sound stage. At the same time I had the wm1a and the m11 sounds more like the wm1a.
    I didn't keep it because I thought the wm1a sounded better. I thought the m5s treble was a bit lacking compared to wm1a and sr15. But the m11 treble is really good. Of course this is from memory, so take it with a grain, but I can say for sure the sound didn't wow me like the m11 did.
    dissembled likes this.
  12. pnzr
    So what's the consensus here regarding poweramps Hi-Res Output? Worth turning on when my library consists of mostly Flac files?
  13. gLer
    For me it doesn’t hurt, sounds as good as FiiO Music, and you get all the benefits of the Poweramp UI and features. I alternate between Poweramp and FiiO Music.
  14. jmills8
    I like Onkyo music app.
  15. FiiO
    Purchase the M11 and Win a free gift(A set of leather case SK-M11) worth USD 25.99 >>>More information
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
