FiiO M11-Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Discussion in 'Portable Source Gear' started by FiiO, Mar 19, 2019.
Tags:
118 119 120 121 122 123 124 125 126 127
129 130 131 132 133 134 135 136 137 138
  1. FiiO
    Dear friend,
    You could send email to support@fiio.com or contact our engineer about that (llc@fiio.net).
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  2. Ryokan
    Player is easy to navigate reading a few posts I thought it would be more complicated.
    Took the SD card from my Sony and once player had scanned it, which took seconds, music showed in library.
    abitdeef likes this.
  3. pnzr
    mhh my M11 is losing battery life like crazy. Had it sitting doing nothing and battery went down by 4% in one hour...anyone else with this problem?
  4. jmills8
    4% per hour is good, right. Can you do the math.
  5. pnzr
    4% per hour doing nothing is good? No playing music, no screen on, nothing.
  6. jmills8
    4% = 1 hour not in use, try 1 hour of use and see how many % ? If not enough fo what I did with my Cowon PM2. I bought two of them so now I have double the battery life. 200% ready, when one in use Ill always have 100 % on stand by. But I also have six other daps each at 100% ready. Plus have five amp/dacs ready. So 1300% ready.
  7. gLer
    Is your Wi-Fi and Bluetooth on? Any apps running in the background?
  8. Ryokan
    Sounds good straight from the box, player can burn in as I'm listening :grin:
  9. jmills8
    If you left the player really in the box will it sounds as good out of the box ?
    Takeanidea likes this.
  10. Ryokan
    Is this a zen question, like a koan: Can you hear the sound of one hand clapping :thinking:
    Takeanidea, pnzr and jmills8 like this.
  11. Leetransform25
    A bit off topic, but can someone explain the differences between the LC-B, LC-C, and LC-D cables? I know the main difference is the materials they're made of, but how does it affect sound quality and the build?
  12. Bobisz
    Ordered mine, cant wait to find out how it compares to the pioneer xdp300r.
    Wanted to get FH7s with them as well but it's going to be a couple more weeks till they are available in Hungary.
  13. abitdeef
    John's bass solo on this track has never sounded better. It's so fast on a lesser dap it kind of blends together. But with the speed and space of the m11 you can hear the shred :)
    I definitly have to re-rip some stuff.
    gLer likes this.
  14. gLer
    Noooooo........MP3......... :fearful:
  15. jmills8
    Funny thing is I have MP3 sounding better or as good as DSD. I also had Flacs sounding worse than MP3s.
    BadReligionPunk likes this.
