audiopoor
- Apr 23, 2011
I'm pretty sure that all three of those BB OPA2134's are in the signal path so upgrading all of them should be fine. The thing is that the only dual op amp that is better on paper without tradeoffs here and there is the National 4562. In circuit the differences would be slight if audible at all. The 2134 is a FET input design, however, and it might sound slightly warmer overall than the newer, but slightly quieter 4562.
As for the pot, the one in use is apparently a high grade conductive plastic (inherently low noise) one. I believe the rotation noise is caused by a slight amount of output dc offset (mV) from the op amps, whose outputs are thankfully not capacitor coupled to block the dc from the pot sections. No one wants any electrolytics in the signal path and the large value film caps that would be required as the better alternative to block the dc offset would never fit in the case. I cannot believe anyone is bothered by the rotational noise. It has nothing to do with elegant engineering and everything to do with sound quality. To me it is nothing to waste time thinking about. Trust me. We do not want our volume controls on a chip.
I got my new E9 yesterday and after letting it warm up for a half hour I gave it a listen with my also new ATH-A700's. At first listen I was very disappointed. Now I'm a music lover/audiophile and because I have a 40 year collection of vinyl and cd, I'm not into computer audio or games for that matter. Maybe I have a different sonic reference point than most portable/computer/game heads but I thought the E9 sounded awful. As an amplifier designer I can tell you that amps do burn in but the sonic changes are slight unless we are talking about old electrolytics in use (rare) that have not undergone complete reforming. Transducers do benefit from break-in but while there are sometimes sonic improvements they are never dramatic, imo.
Anyway I found the E9 to be highly colored, bright, shrill, lacking in low end depth and quality, but surprisingly stone quiet. I modified the switching power supply lead with ten turns around a silicon steel core, but it's doubtful I zeroed in on whatever switching harmonics are reaching the E9, but it's likely not necessary anyway. Previously I was listening to my preamp's headphone output which is built around the pathetic, ancient 4556 headphone specific op amp. That it sounded better to me than the E9 had me scratching my head let me tell you. I'm traumatized.
Looking at the E9 internals, I can see no components which might contribute to this sound character and I see no coupling caps or what would appear to be coupling caps. A review of the E9's impressive specs. would give one the expectation of outstanding sound quality. It could be the new headphones so I'll listen again later tonight with my older 990's or 580's for comparison. For the hell of it I left the combo playing with a pretty dynamic cd on repeat at mid volume for about 12 hours. I'll let you know what transpires with some of my other phones. I really don't want to return the unit which essentially cost nothing in real dollars at only $129.
