shotgunshane
- Sep 25, 2010
Preorder is up on Mp4nation.
What other sites can I get High quality music from? Most all my music is itunes and some CD rips... had I known, would have used other sites. Sadly I already built up my music library, using up lots of cash... to re-purchase would be insane. Maybe just specific songs I really like... (purchase again).
I take it that the E10 is better for (exclusively)home usage?
Or maybe just get an e17 as it should be able to handle 250ohm headphones shouldn't it?
They really give the appearance of it being released with the product on their website and their facebook posts go - e17 coming soon and then a bit higher- New DAC and amp e17. IDK if you've seen these pictures but I will post them again
head fi doesn't encourage music places. or how to atain these lossless music on public and searchable forums. PM me for more info
If u just use it at home. Then yes
After posting and spamming all these FiiO pages i have learned. You get whatever depending on use and if you need it or not. Do you need the better sounding amp? Do you need the more powerful amp? Do you need optical and coaxil capabilites or am thinking about using them? Are you going to be using the DAC? IF you answer is yes to most of these questions. The E17 is for you.
There is no new DAC in the E17. Same WM8740 in others. New DAC would require too much power, and they've already cut almost 80% off the life of E17 as compared to the E7 even with the 50% larger battery :O
What happened to the e15? Is it still in the works? Any potential release timeframe?
There's already way many e17 threads, I wonder how many there will be once people start getting them
Why is it only $135 as PREORDER on mp4nation? Is this the real deal?
don't know. don't care. I had bad experiences ordering from non major retailers in my country. I'll stick with Amazon when it arrices on there. First Batches could have problems...and buying from amazon...gets those problems/bugs fixed
Sigh...Can't decide if I should pre-order or wait for http://www.headphonebar.com/ to get it since I probably cannot get it from amazon regardless.
EDIT: headphone bar does have it for pre-order as well for 139. I will most likely get it from here then.
my heart skpped a beat when i thought i saw it for $250.....it was the E17 and E9 combo
I would rather pay $10 for peace of heart knowing that i bought from an American supplier and form Amazon that can guarantee me an return/warranty in case problems do arise.
