peternguyen
- Oct 29, 2009
You are right. The prototype I received earlier has the 12dB gain disable on USB-in (probably because they fear that the output might clip the amp). But it seems FiiO has enable the 12dB gain on USB-in for the retail unit.
It should be okay to connect it permanently to PC. But take note that the battery won't be used and, like all Li-ion battery, it is not healthy for the battery in the long run. If you can, try draining the battery at least once per month so it gets some proper charging cycle. This will prolong the battery life.
Thanks, ClieOS. Would you be able to explain a little bit about how gain works and when it is best used?
