Alright, I'm not the most qualified person to answer but some of my answers would be:
Since I have barely missed both times Miccastore has had stock recently and fell for AdvancedMP3Players in stock/out of stock scam I am in the pool of those anxiously waiting to get my hands on one later this month. To kill the time I guess I'll ask those fortunate owners a few questions that have been in the back of my mind.
On the design vs the E7:
- Any one that has used both prefer the only style of having the buttons of the side of the device vs buttons on the face of the device? Has feiao explained why they made this change? It seems to me that this would be annoying when having the E17 banded to your DAP "back-to-back" to have to flip it on one side to control the play and the other side to control the volume. Also, are there any issues with placing the E17 face down (screen scratches), I realized there is a button lock but also seems annoying to have to constantly flip it after every adjustment.
- I've seen estimates of the E17 battery between 8.5 and 15 hours, this also seems as a step down from the 80 hour playtime of the E7. Has this been a hindrance to anyone?
I already have a PA2V2 portable amp that I was about to sell until I purchased a Fiio L9 LOD (should have done that a long time ago, doh!) and realized it sounds pretty good from my iPod and improves my sound a bit. How much of and improvement could I expect in the amp department?
The other issue is the DAC, while I have a Creative XtremeMusic card that doesn't sound too bad to me(!) I'm sure I can get better sound from my computer. How do the sound card (ASUS Xonar ST, etc) options look compared to the DAC on the E17 if I'm not concerned about portability?
Thanks for any help!
1. (did not own a E7) I sure bet it's different, but I don't find much trouble with pressing the buttons on its face. The e17 is much smaller than, say, an iphone anyway, so having buttons on the same side doesn't equal better usability IMO. Though in general I find the volume I want and it's locked there. Yeah, flipping it around can be annoying for some. Once you get used to the shape and form you can operate it by ear though; the volume buttons are, however, not highly raised so you may not succeed with gloves on.
2. The battery life seems to be about that long, yes. It lasts me through one to two days listening on the go. As a DAC even without USB charging on, it goes way beyond that. Seems when plugged to the computer it doesn't (or barely) use the batteries; ClieOS confirmed this in the early posts of this thread. So to me, it's not anymore inconvenient than my 4S, cause that thing dies just about as quickly or even sooner.
I'm thinking of getting my first DAC Amp and this one is fairly cheap and sounds like it is a winner. Couple of questions, first:
My laptop doesn't show USB as a playback device. Will my laptop automatically load a USB sound driver when it detects the E17 connected to it?
The writeup (thanks ClieOS) says that the SPDIF port accepts both optical and coax. Does the E17 come with the adapters for both forms of plugs to work with the SPDIF port, or is that extra?
It won't show USB playback unless there is a USB playback capable device plugged in your laptop, unlike HDMI. Also make sure you set to visible all the disabled devices if you want to see all the stuff you can use currently; USB will not be there though.
What OS do you use? I have Windows 7 x64 and it works (never tried with my desktop, which is 32bit). In fact, it switches automatically to the e17 the moment it is plugged in. Naturally you can disable it if you want. I believe there is an option to let your computer automatically switch to whatever device is plugged in, but I don't remember and cannot confirm this at the moment.
And yes, it does come with two small adapters. I've never used the SPDIF, neither optical nor coaxial, but they do come with the adapters. (EDIT: bowei beat me to the reply! read his post above for details regarding this)
