choisan
seeing so much comments on XR, so should one consider to go for Adel? Please!
Please read deezel's many self quotesseeing so much comments on XR, so should one consider to go for Adel? Please!
thanks for the input, i will also look into deezel's post.
so, for whichever iem brand with similar Adel, Apex, is it the same which it will decrease clarity/separation?
shall i assume they are the same technology or theory?
Quite strangely, the demo and custom VE8 sound super different. The custom is much more coherent and smooth.appreicate your time and effort. my wife tested the xra and loved it, she ordered it.
i am thinking to go mine for the same xra or just xr.
the bad thing is that the shop which offered the demo unit doesn's have xr
Do you think the Zeus was re tuned for the ADEL versions ?Keep in mind the Zeus has two sound signatures,--- R and XlV. The XR combines both with a switch to select either, for $300 over the cost of either the R or the XlV. It's not clear to me from this discussion WHICH Zeus is being referenced. The R, to my ears, is a bit flatter than is the XlV. That said, I keep my XR almost exclusively on the XlV side. Bottom line, though, is that the Zeus is not a rumbly bass IEM. It's strength seems to be a naturalness of sound that is pleasing over long listening sessions. And I also assume we aren't discussing ADEL, as that is an entirely different kettle of fish.
i don't think the shop has it. it didn't really want me to buy ea.
is the carrot or 01 module a bundled with xra?
